Used toner bottle
I can't find the used toner bottle
  • bstjcjc Aug 22, 2008
    i can't find the used toner bottle on a ricoh lanier lw310
  • Anonymous Dec 18, 2008
    LANIER used toner bottle full
    Problem Solver:
  • 3 Answers
I had a Ricoh once can't remember the model but it was in the back of the machine. Hope this helps
Posted on Sep 23, 2008
Toner problem
Mam, First remove the toner bottle. Turn of the power. Then turn on the power. without he toner bottle in the machince. Let the machine then run thur its normal program. When the machine asks for a new toner install the bottle. Also check the toner bottle, ensure the nub that sticks out is not damaged if it is dented in anyway replace with a new bottle. That nub is what toner motor uses to turn the bottle, if damage the motor will not get a good whole on the bottle. If that does not work you may need a new image unit.
Mar 05, 2014 | Minolta DI251F Laser Printer
Clicking noises coming from konica minolta di2010f copier after changing toner cartridge
Using the correct toner bottle not a EP2010 bottle or biz hub toner bottle, make sure using the correct bottle, if correct bottle turn the machine off remove the toner bottle turn the machine on without the bottle in it. let the machine do its thing when it ask for toner install the bottle correctly. if the nub on the bottle is damaged then get a new one that is what the toner bottle motor uses to turn the bottle if it is damaged its clicking because its trying to turn the bottle.
Sep 17, 2012 | Minolta DI-2010F Copier
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Add toner
replace toner supply unit. inside of the unit are 4 mylars to push toner towards hopper exit gate. looks like them mylars are ripped off and the toner is not getting to the dev unit
Oct 20, 2008 | Ricoh Aficio 1035 Copier
I use a Lexmark color laser printer. Used toner accumulates in the waste toner bottle. Can I throw the toner away in the trash and reuse the bottle, or am I supposed to throw the used toner and bottle...
The excess toner can just be discarded, and it will not be hazardous to the environment. Toner is simply a dyed carbon powder. I would recommend rinsing it down the drain or disposing it into a plastic bag to prevent a big mess. Toner is very difficult to clean up if you spill it, so clean carefully.
Jul 21, 2008 | Lexmark Office Equipment & Supplies
Panasonic DP-1810P Laser Copier
The copier has an "eye" that detects when the waste toner bottle is full. If you dump it and reuse it, the residue can build up and cause the machine to "think" the bottle is still full. I experienced the same problem. If you re-use an old bottle, after emptying, rinse our any remaining residue and dry the bottle out. Your copier should then notice the bottle being empty.
Mar 14, 2008 | Panasonic DP-1810P Laser Printer
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
389 people viewed this question
k24674
jasbo
jasbo
