Question about Canon CLC 1000 Color Copier
What wrong with my canon ---- error code= e063-0363
When turn on my clc1000 i have this error e063-0363. what it means and what can i do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
More than likely there is a broken microswitch for the transfer/ seperation unit... here's a lil' tip, the unit runs the wire cleaners during startup and it is not detecting the HP of the T/S Corona Wire Cleaner... between you and me, the wire cleaners do not really do a whole lot to help or correct the image (don't tell cust. that, because engineers put that in to make them feel that they are doing useful maintenance), most techs in the field will just turn the check off in service mode... in service mode select the following Copier/Option/User/W-CLN and set it to a 0. I have seen guys just doing a PM on a unit, and get called back the next day because of the lil'swich... trust me, nothing makes customers feel reassured about their machine then when it throws a E-code the day after a PM... save yourself the time and turn it off.... but you didn't hear that from me... other possibility is if you had swervice done previously then they may have forgotten to put the screws bac that hold the assembly.
Posted on Aug 22, 2008
Canon CLC 1000 error code E075 - 0004 please help me get rid of it
[Phenomenon]
Error code E075
[Cause]
Because of the factors listed below, some problems may occur in the controls to prevent the transfer belt
shifting to one side due to malfunctions of the swing motor assembly and in such a case error code E075 gets
displayed.
1) Sliding fault of the part A in the Fig.1
2) Deformation of the sheet metal of the swing motor assembly
[Factory measures]
1) The resinous material has been added, as shown in the Fig. 2, to improve sliding.
2) The reinforcing sheet metal has been added, as shown in the Fig. 2, to prevent deformation of the sheet
metal of the swing motor assembly.
When the error code E075 gets displayed, run checks as described in the Service Bulletin CLC1000-005
(CAUSE OF PROBLEMS BROUGHT ABOUT BY ERRORS OF THE TRANSFER BELT
MECHANISM). If the error code E075 still gets displayed even after running the checks, replace the old
swing motor assembly with the new type by, following the instructions on removing the transfer belt swing
motor assembly described on page 4-50 of the Service Manual.
Affected machines
NFH01171 and later
PFH00044 and later
QFH00129 and later
RFH00079 and later
SFH00221 and later
TFH00127 and later
UFH00657 and later
Jun 11, 2010 | Canon CLC 1000 Color Copier
Hi i am gettin E061 0423 error on the canon clc1000, what is the problem, and how can i turn this copier on service mode. tanks a lot
try "*” (Additional Functions) button, then immediately pressing “2” and “8” together, followed by the “*” again. This is known affectionately as the “star-twenty-eight-star” among Canon service techs.
Apr 03, 2010 | Canon CLC 1000 Color Copier
Hi i am getting E061 0127 on canon clc1000, what is this error means? thanks
Basicly the code means that one of the 4 drums is not charging correctly. You may have to change the post charge wires and or one of the drums
Apr 02, 2010 | Canon CLC 1000 Color Copier
I need help fixing a Canon 2400 with a burned out external controller.
Do you mean the Colourpass Z90? I might have one in my shop from a clc1000 if you are looking for a whole new one but other than that ...
Dec 04, 2009 | Canon CLC 2400 Color Copier
Error Code E061-0110
This is an old fault.I think its a dirty drum sensor.This needs to be cleaned.Your then need to get into service and clear error code
Nov 16, 2009 | Office Equipment & Supplies
I need to get the drum for clc1000 Tambour code 1355A002(AA) F43-4801-700 and the Developing
Dear sir; please contact with me at 973-533-6778 I can get it for you. HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Canon CLC 1000 Color Copier
Canon CLC1000 E350 code error
you will be unable to make copies but should be able to continue to print from your computer
Dec 02, 2008 | Canon CLC 1150 Color Copier
Whate can i do plz ??
your transfer bed and sheet change the transfer sheet also clean the whole bed
Sep 05, 2008 | Canon CLC 1000 Color Copier
HOW TO CLEAR ERROR E350-0000
Did you recently clear RCON and tried to due a CCD adjust? The problem could be the that the left side glass retainer changed or mared or has a doc feeder been added or removed. There is a bar code on the under side of it. The part number for the 1000/3100 is FF5-4662-020, the 2400 FF5-8802-000
Jan 25, 2008 | Canon CLC 1000 Color Copier
CANON CLC1000
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller.
Dec 02, 2007 | Canon CLC 1000 Color Copier
Canon CLC 1000 Color Copier Logo
260 people viewed this question
old marine
old marine
