Question about HP Photosmart M425 Digital Camera
Batteries can i use lithium batteries in my m425
Lans error.m425-11 ..............m425-21
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | HP Photosmart M425 Digital Camera
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
I Need Help!
my camera was droped and now it displays lens error m425-11 and backward on da screen
Sep 24, 2008 | HP Photosmart M425 Digital Camera
Camera hp m425
try quality batteries like Duracell or Energiser... and also make sure u give ample interval of 2-3min before each snap...
Lens Error M425-12 (7F80) on HP M425
Try taking the SD card out and restart the camera. Also, make sure the batteries are fully charged. There is also a firmware upgrade indicating a problem with the lens getting stuck.
May 13, 2008 | HP Photosmart M425 Digital Camera (5MP,...
Lens error M425-12 (7f80) appears/ camera shuts down
if the blue light flashes 4 times Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Dec 27, 2007 | HP Photosmart M425 Digital Camera
HP photosmart m425
can you help em upload videos?
Dec 08, 2007 | HP Photosmart M425 Digital Camera
My camera won't work at all it just says batteries depleted even with new batteries
try taking the camera to ur local hp dealer and smash it to the ground jump up and down shouting i feel better now ha ha ha ur all nuts michael
Jul 05, 2007 | HP Photosmart M425 Digital Camera
HP Photosmart M425 Digital Camera Logo
37 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
