Question about NetGear WG602 802.11g/b Wireless Access Point
Netgear wg602 Can you confirm me what is out put power of netgear wg602 in milliwatts?
    New Friend:
  • 49 Answers
I thought this sort of answers could be found in user's manual? Huh.. Netgear wg602 manual
Posted on Oct 31, 2015
    Brigadier General:
  • 6,966 Answers
The advertised power output of a NetGear WG602 is 16dbm, using an online converter, that would be 39.81 milliwatts.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 22, 2008
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
NETGEAR AND UPNP
Yes your Router supports UpnP.
http://kbserver.netgear.com/pdf/wg602v3_manual.pdf
Here is the manual where I found the information. Once the manual is open ctrl+F will open a find window. In the find window enter UPnP and click enter on your keyboard. This will take you to the section explaining UPnp and how it works on your router.
Good Luck!!
Aug 13, 2012 | NetGear WG602 802.11g/b Wireless Access...
Can't open 192.168.0.227
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 25, 2012 | NetGear WG602 802.11g/b Wireless Access...
Can't configure netgear access point wg602
try to access the the router by using address 192.168.1.1, if this don't work then reset the router and used the factory setting in the manual
Can't access 192.168.0.227
This configuration IP address is wrong for the Netgear.
http://192.168.0.1
Hello, I have Netgear WG602 V4 access point. now I am facing a problem loging in the product which it will not allow me to get in . I tryed so many times by typing the IP ( 192.168.0.227) but without...
I believe you are using the wrong IP. Try 192.168.0.1 instead. The way you can confirm is go to start>run type in "ipconfig" and press enter. Look for your gateway ipaddress. This is most commonly the IP you need to use to login to the router.
Mar 28, 2011 | NetGear WG602 802.11g/b Wireless Access...
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
How can I configure a netgear wireless access point to talk to my wireless dlink router?
What do you mean by talk? Are you trying to bounce the wireless signal for a greater range?
Nov 21, 2009 | NetGear WG602 802.11g/b Wireless Access...
How to Configyre a wirless adapter
If this is a wireless adapter just install the driver, on the PC (the disk that came with the adapter) then plug it into the PC and connect to the wireless router.
Hope that helped.
Oct 18, 2007 | NetGear WG602 54Mbps Wireless G Access...
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
NetGear WG602 802.11g/b Wireless Access Point Logo
570 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
