Question about Brother HL-2040 Laser Printer
Yellow Toner Light Flashes - won't print
Toner light just started flashing a slow yellow flash & now, it won't print .
I have hit the "go" button 8 times & it did print out the settings & status. Nothing looks of concern. I changed out the toner & drum to a new set. Turned it off for ~ an hour. Toner light still blinks.
Thanks for your help.
  • Anonymous Mar 25, 2014
    printer will not print, toner light came on on yellow
    New Friend:
  • 159 Answers
F the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Sep 06, 2008
  • AK C Sep 10, 2013
    The question is about toner but the answer is about the drum - aren't they two different things??
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my PS3 it as it starts up a yellow light comes on
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Apr 16, 2010 | Sony PlayStation 3 40GB System
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Jan 29, 2009 | HP LaserJet 1300 Printer
HP LASERJEY 1300 YELLOW LIGHT FLASHING
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Flashing Lights
From the User Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
If you don't have a User Guide click on the link below and save it for future reference.
2550n User Guide
If this solution has been helpful, please rate it. Thanks!
Jul 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Brother HL-2040 Laser Printer Logo
810 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
