Question about Brother MFC-465CN InkJet Printer
More suggestions? "the page you are viewing does not support that function, when sending it to the printer."...is not helpful - how can I change the page - I'm just printing like I always have (with a pc for ex). I used to have the option of printing a selection but now it's all or nothing. seems funny to me. (I'm using a Macbook) Thanks again, EV
  • ellen v
    ellen v Aug 22, 2008
    I'll try it, but the drivers were installed properly. Perhaps it's a conspiracy (with the ink company) ;)
  • 876 Answers
Try "save as" a web page or as a txt file in your document folder and go there and print it. Is this a one time thing or is this something that is happening all the time? Is this a new printer installation? Have ou try the compatibility wizard? What is your Op system?
Posted on Aug 22, 2008
SOURCE:
How do I increase the font size on my hp printer when printing from my computer
The font size is usually controlled by the properties of the page you are trying to print. Try increasing the size of the font on the file.
Feb 17, 2015 | HP Office Equipment & Supplies
12/640 PS wont feed from tray
I found the owners manual for your model, and it has detailed explanations of how to turn off the printing of the Startup page: This is where the owners manual is available online in .pdf format, at this URL: http://download.info.apple.com/Apple_Support_Area/Manuals/printers/0340211ALW12640UM.PDF Startup Page Info From your Owners Manual: (Yes, I've been reading the Manual for your printer. I have no life. :P ) From page 25 of the manual: "The printer takes a minute or two to warm up, and then it automatically prints a startup page. It prints the startup page every time you restart unless you turn the startup page off using either the Apple Printer Utility for the Mac OS or the Apple LaserWriter Utility for Windows. See Appendix A for details on these utilities." From page 249 of the manual: "Appendix A - Setting the Printer Default Settings" "Though the printer itself has no control panel, you can configure it by using programs on computers connected to the printer: - On Mac OS?based computers, use the Apple Printer Utility and the desktop printer?s setup function." So the answer is YES, you CAN setup the printer to not print the test page, but you have to use the setup utility on your computer to do so. Opening the Apple Printer Utility (From page 251) "The Apple Printer Utility has two windows: the Printer Selector window, which is similar to the Chooser, and the printer features window, which you use to view or change the printer?s settings." 1. Double-click the Apple Printer Utility. - The Installer puts the Apple Printer Utility in the Apple LaserWriter Software folder. You can move it wherever you like. 2. In the Printer Selector window, select and open the printer you want. - If the network has zones, click the zone where the printer is located. - Click the name of the printer you want. 3. Click Open Printer. - The printer feature window appears with the Printer Information category displayed. 4. To view or change settings under a category, click the arrow beside the category name to open the category and display its information and options. - Additional options may appear that you can also open and work with. When you are finished changing options in a particular category, you can click the arrow again to collapse the options. (NOTE: The option you want is "Startup Page".) 5. After viewing the information and making changes, click the Send button to send your changes to the printer. 6. Click the Close box to close the window. Turning the startup page on or off (From page 257) "The LaserWriter 12/640 PS normally prints a sample page when you turn the printer on. This page shows the printer?s name, the total number of pages printed, the amount of memory, installed options, and communication settings. You can turn this feature off if you wish. 1. Open the Startup Page category. - The Startup Page panel appears. 2. Click the checkbox to turn the startup page on or off. - When an X appears in the checkbox, the printer is set to print the startup page. 3. Click Send to send the startup page setting to the printer. That should remove the default printing of your startup page. HOWEVER, there is another possibility to affect a repair to your problem... As the paper-feed rollers get older, the rubber on the rollers gets slick and won't grip the paper anymore. Try buffing the rubber rollers with some fine sandpaper and see if that allows the machine to pick the paper up once again. If this is your problem, then you might make the lower-feed paper tray work again. Hope this helps, but let us know if you need more information to solve this problem. ;)
Aug 07, 2007 | Apple LaserWriter 12/640 PS Plus Printer
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Increase font size when printing from Google pages
You cannot change the font size if you are using the web page. What I can suggest is to highlight the text that you want to print, then you should have an applications like a Microsoft word, excel, power point etc., Paste it on that application, in that way you can now change the font size and also the font phase.
I hope it help you a lot! Good luck :)
Feb 02, 2011 | Office Equipment & Supplies
How to I prevent the printer from printing the second page with file name location ect?
The printer is just putting the spots on the page. Its told to print the information by the application that is sending he data to the printer.
Since you did not give the application's name, I cannot help you. I suggest that you look in the application's "Preferences" and see if you can find the setting to change the tag lines.
Nov 02, 2009 | HP Deskjet D4260 Printer
How to find page count option
You either hold the go button until the lights flash and it will give a printout or just press the start a couple times for a printout that also gives the print count.
Oct 15, 2009 | HP LaserJet P2015 Printer
"TX Function Not Completed"
Open up the document feeder and check to make sure no switches are trapped down.
Jun 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
LEXMARK X7170
Hi - You can view the manual from the link underlined in blue below:
Lexmark X7170
Changing information that appears on your fax cover page
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  2. Click View Cover Pages.
  3. Click Change your personal information that appears on this page.
  4. Make any changes.
  5. Click OK.
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 21, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Dell AIO 962 copy & fax issues
Go to Dell AIO and click on maintenace/ Troubleshoot on top of the page. Then go to maintain or fix quality problems.
Then choose the problem and run it.
Nov 14, 2007 | Dell 962 Photo All-In-One InkJet Printer
Brother MFC-465CN InkJet Printer Logo
21 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
