Question about Intel DG31PR Motherboard
My MB does not aceppt two devices in IDE. I have one DC reader and one DVD writer and the bios not aceppt. I tried with all of configurations, the power source is 450W, the MB is new and since the first usage the problem is present. The IntelĀ“s support can not help me... Can you help me? Divanil.
  • divanil Aug 23, 2008
    In adiction of my post:
    CD reader is LG model GCR8521-B, DVD writer is LG model GSA-H22N.
    The bios detect devices in master and slave configuration, but not with two devices at same time = the bios program "lock" and I need to turn off the system and not work. With only one device, in any configuration, it works well. The Intel says: "at this time, we not have anything to help you". I tried with all possible configurations, others brands and model of devices and the problem is the same.
    Thank you.
    Problem Solver:
  • 8 Answers
Mode numbers and details please
Posted on Aug 22, 2008
Inaccessable boot device
I really don't know what you mean. Give all the specs of your PC , please also make sure your HDD is not set in your BIOS to RAID, Set it to IDE Mode
Jun 08, 2010 | Intel ASUS P4S800 Motherboard REV. 2.01...
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
My sata Dvd Writer 22xsuper-writermaster SH-223 is not bootable
You should set the First boot device to DVD/CD rom from your Bios , thats it..Nothing other than that , whether it may be SATA or IDE or even the version of Bios doesnt matter..
Rnj VINOD KUMAR
Sep 12, 2009 | Sony Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
I nedd bios upgrade for my laptop clevo m220s
It seems it is a product of SiS. Visit http://www.sis.com.tw and search the BIOS upgrade in the download or support section. If SIS has launched any upgrade for your product, it will be available there. (ehteshamhusain@gmail.com)
Apr 04, 2009 | Computers & Internet
New gigabyte EP45-UD3P mb intel q9400 dvd drive won't burn dvd
many people when doing bios-hardware updates. leave optical drives connected. this can have adverse effects on connected items. the only 2 suggestions i have for you are:-
**** uninstall and re-install the Drive first In device Manager****
1:) if the motherboard has 2 ide slots Primary/secondary. put the dvd writer on the secondary, or vice versa. and setup as a Master Drive. ( jumper block at rear )
2:) Go to lite-ons website. and see if there is a firmware available for that model of DVD Rom drive. and carefully re-flash the drive itsel.
Hope this guides you in the right Direction.
Mike @ compurepair.
Apr 01, 2009 | Intel Motherboard
Sata dvd reader writer Problem installing , keeping it installed
ok reboot you computer and press delete when your bios boot screen appear then go on your hdd-ide-sata screen and look your sata configuration and set it on sata-enhanced or compatible this is becose you are running on windows xp.
bye and good look
Dec 24, 2008 | ASUS A8N-VM Motherboard
IDE controller not working properly
having done these things get in touch and we will go from there
Nov 01, 2008 | Intel D101GGC Motherboard
My LG Combo is not working after i have installed another LG Dvd Writer
I am assuming they are both on the same ide cable. If so set both of the jumpers to CS (cable select) and try rebooting the machine.
If this doesnt work you might have the bios configured to say there is no drive on that ide channel location. If the first option doesnt work let me know and I might be able to help further
Feb 11, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
TSSTcorp CD/DVDW SH-S162L errror code 0x80020043
The problem might be with you cable remove the cable of your writer and plug it to another id port after pluging in install the drivers of the writer, this should solve your problem, if not then go to computer manager in that disk drives in that find the name of your writer. first disable it for a second then enable it now go to its properties and in that just press the button of check for updates, your screen will blink once and your drive will be installed properly.
Please vote me if you like the solution >Karatela
Dec 07, 2007 | Samsung (SH-S162L/BEBN) DVD RW Burner
Intel DG31PR Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
