Question about Panasonic KV S2045C Path-Through Scanner
THAT DAM RED LIGHT THAT WON'T GO AWAY ON THE SCANNER
EVERYTIME I ACCIDENTLY SHUT MY PANASONIC KV-S2045C OFF THIS RED LIGHT INSTEAD OF A GREEN LIGHT APPEARS ON THERE AND TAKES DAYS TO GO AWAY WHAT CAN I DO TO PREVENT THIS FROM HAPPENING AT ALL TIMES AND WHAT TRICKS CAN I PERFORM TO MAKE IT DISAPPEAR?
    Problem Solver:
  • 16 Answers
Most often this is due to a dirty sensor or reflector. dust will often build up over time and cause poor sensor readings and thus a red error light. There are four paper sensor sets on this scanner. Cleaning each of the sensors with canned-air should resolve this issue.
  1. the small black rectangle that is set down inot the paper-feed tray - this is the paper sensor.
  2. whe you open the scanner (like you would to clear a paper jam), on the part of the scanner that swings open and just above the two white plastic rollers, you will see another small black rectangle that has two "eyes" - this is the wait sensor. the wait sensor meets up with a shiny reflector when the door is closed; this reflector is just behind the large rubber roller on the base of the scanner - it may also build a layer of dust and need to be cleaned.
  3. a little further down on the open door, below the wait sensor is the start sensor, and it's reflector is on the base of the scanner just below the second set of small rubber rollers.
  4. the ending sensor is a little harder to get to. if you look into the area where the paper exits the scanner, you will see two blck rubber rollers - between these rollers you will see a "notch" - at the bottom of the notch is the reflector and just above is the ending sensor. this is the most likely cause of your troubles and usually a few strong blasts from the canned air will take care of it. If the reflector is real dirty, you can take a cotton swab and a few drops of rubbing alcohol and work it around in that area.
This is one of the most common scanner-error questions I get! I hope my wording is clear and helps you resolve this problem!
Posted on Dec 02, 2008
I'm getting an "F62-52000000" error
F62 error is a problem with the lamp gain on the rear page camera .
Usually removing the camera & cleaning the optics will sort it out .
The scanner will need a good service & shading adjustment as well .
Only attempt this work if you are familiar with CCD Devices & care, as damage through mistakes can be very expensive .
AP Support Solutions
Aug 05, 2011 | Panasonic KV-S1025C
KV-S2026C not scanning
does this unit show any error?
how old is this unit> is it under warranty?
Oct 02, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Only scans 1/2 back page in duplex scan.
%95 of the times its a technical faliure, Talk to the store you bought it from or call Panasonic customer support, you can not fix this by yourself. =)
Jun 08, 2007 | Panasonic KV S2045C Path-Through Scanner
There is a red light error on the scanner and it beleives there is paper in the scanner. I have unplugged and replugged everything. I have reset the scanner and I have also turned the paper feeder to...
I found someone had placed a piece of tape on the cork where the scanner feeds in which was causing the sensor to believe parper was there. When I removed the tape the red light went off.
Feb 24, 2011 | Panasonic KV-S2026C Pass-Through Scanner
Computer will not boot or respond
Beeping upon startup is generally a problem with memory ..
Mar 13, 2009 | HP Compaq dx2000 PC Desktop
Scanner
check and clean the exit sensor.
You will find then in the middle behind the exit roller in the paper exit area.
Normaly it is unimpossible to see this sensor because the roller axle is in front of them.
It is the same sensor type like the other sensors with an sender/receiver an a reflector foil.
Helpfull to clean will be a q-tips or a small brush.
Jan 23, 2008 | Panasonic KV-S2046C Pass-Through Scanner
Recognition Issue
what operating system are you using?
Dec 12, 2007 | Panasonic KV-S2026C Pass-Through Scanner
Ready/Error Light
IT have just been down to look at our scanner & cleaned the sensor which is in between the rollers just where the paper flits out at the bottom - we now have a green light! So look for that sensor.
Apr 18, 2007 | Panasonic KV-S2046C Pass-Through Scanner
KV S2045C scanner
Wow, it's been so long since I posted this, I cannot remember! I am the tech person and just was relaying the problem as an EX exployee relayed it to me. What did my original message say? I BELIEVE it was 1/2 black, but no image/words on the other half. Just black and white, but again, I cannot remember. Does it make a difference?
Dec 05, 2006 | Panasonic KV S2045C Path-Through Scanner
Panasonic KV S2045C Path-Through Scanner Logo
277 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
