Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
MAYTAG refrigerator (MF12568AES) entering code
The code is 0302 and the control board has been changed. How do I enter the code? There is a PE0 000 on the display.
  • 1 more comment
  • rprather Sep 20, 2008
    Tech replaced both boards and now I have the PE0 000 display but can't get anything to happen when pressing +/-
  • paulettegg Jan 24, 2009
    I have the same problem. Maytag refrigerator MFI2568AEB replaced hv control board in the back of refrigerator and now front panel reads PEO OOO, still cannot use. Please help if you have the same problem, I need to set control.
  • Anonymous May 01, 2009
    Our controller board which was already replaced has been acting up. Tried entering the code 0302 and it does not work.
Call Maytag. They are aware of the problem. When I called them last year, they sent me a new control board for free, but they didn't provide labor. We got someone out here to install the new board thru our home warranty. We paid $65 for the labor. Not sure how much Maytag will charge.
Posted on May 18, 2009
Maytag refrigerator mfi2568aes replaced control board in back and input code and saved. now nothing is running but display is fine
Sometimes the new board will be in defrost mode when you install it, leave it powered up for 30 minutes to see if it begins cooling... Maytag Refrigerator Control Board W10890094
Also be sure the code is entered properly, these will do NOTHING without the right code.
Jul 08, 2016 | Maytag Refrigerators
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
HOW DO I ACCESS THE CONTROL PANEL ON MY MF12568AES
You probably need a new control panel - need to call your home warranty (if you have one) or call Maytag. Can only get one thru them.
Jun 08, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
How do you change the water filter on Maytag MF12568AES?
Check top right inside of frig. Filer is inside the housing; open door turn filter counter-clockwise, the housing should allow you to lower filter to change it out. Place new filter, turn clockwise, push back into place and close door.
Apr 19, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Reprogram control board after replacement/ MFI2266AEU B/M REFRIGERATOR, M'TAG
Press and Hold Door Alarm Keypad
Press and Hold temp down keypad
Relaease door alarm Keypad and wait 3 seconds.
The control will display PE to indicate Programming mode.
Entry to programming mode confirmed by pressing FREEZER temp down keypad once more
The control will display the Current unit Programming Control code This code must be validated by comparing it to the Programming code stamped on the unit data plate (Model number plate)
If the programming code is correct all you have to do is close the refrigerator doors
To change the CODE press the REFRIGERATOR up or down keypad to change the digits.
To move between digits press the FREEZER up or down button. Decimal point indicates selection
Once the desired code is entered PRESS and HOLD the freezer temp down button until the CODE entered starts flashing.
Close the refrigerator doors or wait 4 minutes without Kaypad input for programming mode to exit.
That should be what you needed.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Maytag MFI2266AE Side by Side Bottom...
I just replace my control board and freezer fan. I plug the refrigerator in and I get the PE0000 code. I try to go into the program mode by pressing door alarm and then freezer down key for three seconds...
I just fixed mine. With the PE00 0000 flashing press and hold the door alarm key, press the freezer down (-) button and hold, then release the door alarm button. after about a second release the freezer down button and the display should change to a steady PE00 0000 after about 3 seconds. Using the refrigerator + - buttons you change the code. The freezer + - buttons now control the position of the decimal point to change each number position. My code was 0302 (found on the sticker on the inside of the frig, right hand upper side. I had to follow the programming code found behind the kick plate on the right side twice, the second time it worked.
Apr 08, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
My Maytag MF12568AES Refrierator control panel flashes on and off and the door flapper to te ice maker opens and closes uncontrolably. Whats up?
this is a very common issue the control board on the back of the unit is bad, you will need to replace it to fix this issue, let me know if you need more help,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Aug 03, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
1,747 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
