Intel Motherboard Logo
Posted on Aug 22, 2008
Flahed wrong bios
I flashed wrong bos in my ecs p4m900t-m2 ver 1.0 board. and now it does not let me flash again. the temp monitor also doen not work. i have a problem in my pendrive the files does not gets read like mp3 it does not plays after some time. need help urgently
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 22, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
4399
Points
9
Simple. get the board over to a friend. Be careful with this step now..
loosen the bios on the friend's motherboard so that it just touches the contacts and once it boots into a dos mode swap it with your bios and flash the correct one. remember to be very very careful about how you insert the bios chip.
it works as i have done it for my old k8v-vm ultra
Can not see sata hard disck
Hello try to download the manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=822
And read the basic setup procedure, for the harddrives in the bios.
Good luck
Overclocking ECS P4M900T. Pocessore Intel dual core E 2140.Come si procede?
Tu non lo posso fare con quella motherboard, troppo semplice, no ha le necessare optioni nell BIOS.
I have a P4M900T-M2 mobo, and I would like to buy an Intel Q8400 (2.66G) 4mb 1333fsb. But P4M900T-M2 mobo says.. -> FSB 1066/800/533 MHz and an Intel Q8400 has FSB 1333Mhz Will the two of...
No, the one you want will not work simply because it's too powerful for the board and will not be recognized. Here you can find all supported processors
http://www.cpu-upgrade.com/mb-ECS/P4M900T-M2(V1.0).html
as you can see the only ones for your mobo are Q6600 and Q6700.
1helpful
Out of date my driver?
you mean driver for ecs p4m900t-mm2 ?
if yes
go to this link http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=P4M900T-M2
or visit manufacture website.
3helpful
2answers
I want ecs p4m900t-m2 motherboard dirver
You can find all the necessary drivers from this link.. http://downloadnew.org/list/ecs-p4m900t-m2-v10-audio-driver/, check out the site slowly, you may skip something. All drivers are free. Good luck.
7helpful
3answers
Download driver "ELITE P4M900T-M2"
try this site
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=822&DetailName=Bios&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
that will have them...hope this helps
8helpful
2answers
I CAN NOT DOWNLOAD THE DRIVER FOR ECS P4M900T-M2 SOCKET 775 MOTHERBOARD. CAN YOU HELP ME?
Try EliteGroup support for your product: (under Downloads, click on Driver - choose the correct driver for your operating system)
EliteGroup P4M900T-M2
2answers
No video.
Try to check your monitor cable.. Is it ok?
Tons of problems
Hi freak761, it sounds like the bios was corrupted. Contact ECS through their online technical support, click on this link; http://www.ecs.com.tw/ECSWebSite/Support/TSSRequest.aspx?CategoryID=1&MenuID=19&LanID=0
Fill out the required information. Request a new "updated" bios for your board. Most manufactures charge $5.00 US for a new bios. ECS's web site for the P4M900T-M2 V1.0
With respect to your Hisun pen drive. Many people claim the total size of their pendrive may be fake.
There is a suggested test program that might help. Run, Bart's Stuff Test 5 Version 5.1.4 to help check your pendrive. http://www.google.com/search?hl=en&q=Bart%27s+Stuff+Test+5&btnG=Google+Search&aq=f&oq=
In windows XP you can also use windows disk manager. Open windows run window & type in diskmgmt.msc than click ok. Format the partition of the pendrive through disk manager.
Mike
SAFE OPERATING TEMPRATURE ECS P4M900T-M2
Most computers operate about 45 to 50 degrees at normal usage can go a bit higher when gaming but should not go over 65 to 70
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
