Question about LG LFC25760 French Door Refrigerator
Ice maker on a LG LRFC25750ST
It took me a year to get around to hooking up the water line and now the ice maker will not go on. It worked when I bought the refrigerator, but now it does not. Also There is red and blue wires leading to the water valve. Which one goes to the left and which to the right? Not that it matters since the ice maker seems to have no power.
  • Stackarack1 Aug 25, 2008
    You were correct. The thermal fuse was blown. I checked with my meter and had no power. Replaced fuse and now everything is working well. Thank you.
  • 157 Answers
Hello sir
Posted on Aug 22, 2008
  • John Smith
    John Smith Aug 22, 2008
    check the wires are connected to the right place
    It may be that there is no power in the wires so id suggest you get a tester and make sure wires are carrying power to the ice maker
  • John Smith
    It really doesnt matter which wire goes to the left or right
    As long as both wires are connected, then thats tops
I have a frigidaire refrigerator with a top freezer , I put a ice maker in and the water is going to the bottom of the frig but not going up the line to the ice maker , but you can't hear the ice make
if the water is turned on you probably have a bad valve take the line off of the valve
at the back of the refrigerator see if you have water if you do its the valve
Oct 10, 2014 | Frigidaire Refrigerators
My LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING INTO THE ICE MAKER AND MAKING FOUL SMELLING AND TASTING ICE. ...
Having ice maker hooked up to hot water side is common practice...because the water is heated before it gets to be sent to the ice maker, it would have less air in the ice...kinda like a crude way to distill the water.
The sludge is from mineral deposits in your water...sometimes called hard water.
One of the best investments in areas of hard water is a water softener system, in-line water filters, or a combination of both.
Ya might look to see if there is a filter in the refrigerator to filter water before it gets to the ice maker as well.
Hope this helps...
Jul 24, 2011 | LG Refrigerators
LG LFX23961ST with error code ER IF
could be bad fan. sometimes the sensors on the them go bad
Apr 22, 2010 | LG LFX23961ST Stainless Steel Bottom...
Ice maker does not make ice. Water supply works, but ice machine is dry.
if it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Nov 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Ice maker problems
I have seen alot more module problems on that unit then valve problems but i have seen some valve coils go out. First turn the ice maker off for an hour or so then move the arm back down. If it goes around and doesn't fill with water with the valve all hooked back up properly then your looking at a valve. If the ice maker doesn't go all the way around or doesn't start at all pull the white front cover off, it just snaps on, and see if a little white plastic peice falls out or if you can just pull the big round gear off. There is power behind the gear put the cover back on don't change it with unit plugged in.
Apr 23, 2008 | Whirlpool ED2FHEXN Side by Side...
HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Apr 22, 2008 | Refrigerators
LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Jan 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
LG LFC25760 French Door Refrigerator Logo
335 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
