Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Side by side
After power went on off severl times in a row, frig is making a clicking sound like something is trying to come on, and now frig is not running, getting warmer in both compartments.
  • 38 Answers
The clicking sound is either from your fan clicking against ice that's built up or from your compressor trying to kick on. Unplug your fridge and let it defrost for a day with the doors open. You will want to put everything in a cooler with plenty of ice. The next day plug your fridge back in. This should solve the click if it's your fan. If it doesn't then the click is in the compressor and you will need to hard start it. Hard starting a fridge is the equivalant of jumpstarting a car. It requires a specific machine. What happened was at the moment your compressor was going to kick on the power failed and so the compressor is frozen. Not temperature wise but figuratively. It needs a boost to get it kicking again. If you don't have a hard start machine consult fixya's local directory. This should just be a minimum service charge. I would try unplugging the fridge for a day first. It's cheaper. I hope this helps.
Posted on Sep 11, 2008
My whirlpool ED5VHEXV001 frig is not cooling well; freezer is doing just fine. Found beaucoup dust clogging the heat dissipating coils under frig. Cleaned 1st row of heat dissipating coils. Frig is now...
You can purchase special cleaning brushes to do that - BUT since I purchased one, I used it when I first got it and then put it away somewhere and can't find it. So I had to figure something else out, and what seems to work the best is to turn on the vacuum and put on the floor in front of the unit and then use an air compressor blowing it out from the rear. While it does blow dust into the kitchen, it seems to work well as cleaning out the condenser coils.
Aug 06, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a 5 yo Maytag side-by-side frig. A few days ago the frig started making a buzzing sound that happens every so many minutes and lasts a couple of min. Today it started dripping water from the port...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Maytag Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Clicking sound coming from the vent area on the top back left wall on frig side of a Frigidaire GLRS264ZA. The clicking sound comes and goes. Frig and freezer still seem to be working fine. Any ideas on...
the clicking is probably normal . in that area is the a d c some thremostates / . can't be fan as it in freezer ,, don't fix what isn't broken . relays have just a light click / they are not very loud . with the door closed you should not be able to hear them. mm
Dec 09, 2009 | Frigidaire GLRS264ZA Side by Side...
I have a maytag side by side frig. Today I walked
Below is 2 links you can click to view the fountain. Thanks, Sea Breeze I believe that your board ot the water solenoid is defective.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171257
http://servicepartstec.blogspot.com/ Enter model number on this link, they also offer free assistance. Model number MSD2735GRS
Apr 30, 2009 | Maytag MSD2736GR Side by Side Refrigerator
Frig making bang sound??
control is to high if lower control and noise still there change compressor
Mar 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Went to put groceries in frig and found it not on
yoor lights should be on at the very least, i would check the outlet , plug in a hair dryer or something, no internal lights means you have no incoming power supply
Dec 17, 2008 | Maytag MCD2257HES Side by Side...
Frig and Freezer not working.
Beware I bought a Frigidaire side by side in 2006 and the compressor went out in March 2008, the warranty was out in Jan, and the repair man came out and said it was a 2004 model, you might have the same one as I had, they know the compressors are bad in the frig's and you only pay,$160.something if I remember. It sounds just like the problem I had, good luck!
Mar 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
