Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
Install a disk in drive F?
I may have accidentally corrupted my PNY4GB Flash Drive and its only two weeks old! When I plug it in to the USB port I get the safely remove indication in the tray. When I go to 'my computer' it shows the icon for removable Disk F but when I click on it it says "please install a disk in drive F".
Properties show it as empty? How do i re-install the manufacturers software or possibly recover my lost files?
  • Anonymous Sep 09, 2008
    Problem Solver:
  • 13 Answers
Download this file from PNY to reformat your Flash Drive. It should work after that. Get the file here:
http://www2.pny.com/support/media//Files/06c3418a-bd4a-4a67-a7b7-f4415a58338a/Pre-test_v1.zip
Posted on Nov 19, 2008
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Hi , My san disk 4gb cruzer micro flash drive has the LED on when i plug it to any computer but doesn't show up on My Computer , Disk management or Device manager . I have tried 3 different desktop...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
May 30, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have an HP pen drive 4GB. From last one week it is not being detected in any system.
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows). Otherwise format the USB flash drive in NTFS.
Insert the flash or external hard drive into the USB port then Click on ControlPanel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flashdrive has been formatted it will indicate that it is Health
Feb 07, 2011 | Computers & Internet
When i plug in the u3 flash drive it says usb device not recognized
Hi ,dkjran,
If your computer affected by virus will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
hope it will help you
Dec 12, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have an HP pavilion dv6000 laptop and it has been really slow for about a month. It froze up yesterday and I had to cut it off and back on and when i did not it just boots up for a few seconds cuts off...
You could buy a new (bigger? faster RPM?) disk-drive, and remove the old disk-drive.
Install Windows onto the new disk-drive.
Then, buy an adapter (USB connector at one end, and adapter for a disk-drive at the other end).
Connect the old disk-drive to the adapter, and connect it to a USB port on your computer.
Copy all your important stuff from the old disk-drive to the new disk-drive.
All your files will be there, even though the "essential" files that you need to start-up Windows have been corrupted.
Finally, buy an external disk-drive, and use it to create weekly backups of your stuff.
Do NOT delete the files from your disk-drive, to leave the ONLY copy of your files on the external drive.
Nov 26, 2010 | Computers & Internet
I need to remove some photos from an old computer. Windows 98;. Is not able to be connected to wireless internet. I bought a Cruzer Blade USB Flash Drive 4 gb. Will not work. As I cannot download a...
If the Windows 98 computer does not have a USB port and you cannot copy the photos onto a floppy disk or burn the photos to a CD then the only option is the following.
Remove the hard disk and connect it to a USB hard drive adapter and then plug this into a USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and copy your photos to this computer or to a USB flash drive.
Oct 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Usb pulled out during use now not working
Sometimes when a flash memory stick or USB hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory or USB external hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 27, 2009 | Western Digital My Book (WDG1U2500)...
Pluging in your flash drive to any usb port
sounds like you need a driver for your flash drive, if it used to work then the driver is probably corrupt. Remove the driver via device manager and install it fresh
Regards
Tony
Dec 04, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
242 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
