Question about Dishwashers
D3122 has error L2 is there anything i can do or does it need a tech
  • deno66 Aug 23, 2008
    just received d3122 yesterday on its third wash and has same l2 error this is not good for a new machine, Will call store or asko asap, not happy jan.
Pull the power plug. Place a towel well under back right corner. Lift front left corner water will run out of unit give it a minute. When you power back on, the front panel lights will be on but now you will be able to turn off the unit using the power button on top of the door. Any residual water should evaporate over time. Ensure the unit is level and no hoses are pinched or kinked. Test unit if L2 error occurs again it would suggest an internal leak a tech would be needed.
Posted on Aug 24, 2008
Error stat
Are the data in L1 and l2 in any way related? If they are (being x-values and y-values of some data set) then you need to do regression analysis (2-var stats)
If they are not related (connected) you can calculate the mean of each group separately.
Do 1-var stat by specifying the L1 list first (may be the default), get your average of the values in L1. Then you can do 1-var stat on the data in L2 by specifying the list L2 on the command line.
1-var L2 ENTER
Note: What I am describing here is valid for the TI 83 Plus/TI84 Plus, but I suspect the steps are similar to the TI 82.
Oct 08, 2013 | Texas Instruments TI-82 Calculator
Hello, I have a HP Photosmart D5460 Printer and all I did was change the printer cartridge and now I cannot get the printer to print can you please help
This particular issue, i.e. 'ink system failure' with the error code starting with 0xc19a for teh Photosmart C6300, D5400 and D7500 is being handled by the Level 2 techs at HP and all L1 agents have been instructed to transfer the call to the L2 techs. So give a call to HP Tech Support and they will take care of this one way or the other.
Jun 03, 2011 | HP Office Equipment & Supplies
I have data entered in L1 and L3. And I want to take the log of L3 in L2. But after I do that it gives me an error. How can I fix this.
If the data in your L3 list contains only positive numbers there is no reason why you should not be able to calculate the log of the list and store that in L2.
  1. You open the list editor, [STAT][1:Edit]
  2. Use arrows to position the cursor on an element of L2.
  3. Use UpArrow to highlight the L2 heading (at the top of the list) and press ENTER.
  4. The data entry line will show L2= ..
  5. Erase anything that may be on the L2 entry line and type in
  6. [LOG] [2nd] [3] (L3) to enter the L3 identifier inside the log (
  7. Close the right parenthesis. Screen shows L2= log(L3)
  8. Press [ENTER]
  9. The L2 list will be populated with the logs of the elements of L3.
Hope it helps
Dec 08, 2009 | Texas Instruments TI-83 Plus Calculator
I am getting a lens error message on my nikon coolpix L2 Camera
Try cleaning out any grit in the lens barrel with compressed air and wiggling the lens gently. If that doesn't do it, the camera needs servicing.
Oct 04, 2009 | Nikon COOLPIX L2 Digital Camera
Panasonic DMR-e80HS won't play
L2 is not an error message,it is the indication for LINE2 input.
Messure the 12 and 5 V lines ,if not correct i would suspect some bad caps in the power supply
Jul 24, 2009 | Panasonic DMR-E80H DVD Recorder
Need a new processor
http://www.dell.com/content/products/productdetails.aspx/inspn_e1405?c=us&cs=22&l=en&s=dfh&~section=specs#tabtop
Select Tech Specs:
Intel® CoreTM 2 Duo Processor T5500 (1.66GHz, 2MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T5600 (1.83GHz, 2MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T7200 (2GHz, 4MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T7400 (2.16GHz, 4MB L2 Cache, 667MHz FSB) You can order the processor from Dell sales and then take it to a local computer shop like Fry's. And they can can install it for a good price. I normally would not recommend replacing a laptop processor unless you have done it previously several times.
Apr 29, 2009 | Computers & Internet
Lens error
i had the same problem....my problem was the lens was pushed forward and the third zoom was pushed back. so the lens is blocking the cover(thing that covers the lens) so push the lens back carefully with a cottom swab and pull the third zoomer thingy out.
Jul 31, 2008 | Nikon COOLPIX L2 Digital Camera
Xerox 4045 laser printer L2 and L3 errors
Hi Derek:
I checked my stash and I don't have a manual for this specific model. However, you can purchase a service manual for $11.99:
http://www.service-manual.net/ashop/catalogue.php?exp=&cat=249&gclid=CNPtiryPuJECFQyhiQodHihsNg
Good luck my friend.
SeekPCRepair
Feb 08, 2008 | Office Equipment & Supplies
Lens Error
Thus suggests a dirt entrapment. You will need a repair ship to look at it or go to Nikon website for this cameras model for Tech Support
May 17, 2007 | Nikon COOLPIX L2 Digital Camera
Dishwashers Logo
331 people viewed this question
Top Dishwashers Experts
