Question about Kirby Heritage II Vacuum
Turning itself off
The fan was replaced recently, and the repair place overode the automatic shut off which normally occurs when the hose is disengaged. Tonight the cleaner kept stopping, and would start up again when the hose was disengaged, and would continue working for a short period of time after being reengaged. The periods of the cleaner working shortened until it would not work at all. I would love to get it working again, particularly as I have all the adaptions, which I am led to believe are incompatible with the newer models.
  • Kirby Expert
  • 324 Answers
With newer models will not work things that you attach to the vacuum such as the hose and the carpet shampoo attachment. Loose attachments will work just fine. It is same diameter holes that are being used in later models.
Switch - there is not much you can do without getting inside of the vacuum. You have to access inside and get it fixed.
Rocky
Posted on Nov 06, 2008
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Kirby G5 shuts off by itself
this could be a couple of things, first I am suspecting it may be the cord. goes for so long and shuts off, possible break in the cord. Usually the machine will have normal operation at this point.
Overheating or unusual warmness coming from the machine itself, could be a possible motor problem. Usually a burning smell is associated with this.
Thirdly, perhaps the "deadman" switches are not covered properly. this could be as simple as the bag container where it joins to the machine has come loose or dislodged enough to shut the machine down. There is also another deadman switch located on the brush housing and the attachment hose. If those have been switched recently try re-switching it back off and on again to see if that corrects the problem.
Good luck!!
Jan 24, 2012 | Kirby G5 Bagged Upright Vacuum
Vacuum goes on for a few seconds then shuts itself off when I go to start again it goes for a few seconds then stops new bag in vacuum can I fix this problem Donna
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Apr 06, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
While vacuuming the red light for the bag of the vacuum came on and the vacuum stopped. The bag was no where near full so I replaced it with a new bag - same problem. It vaccumes for a minute or then stops...
I'm assuming this is the Epic 6500 or similar model.
Detach the hose, turn vacuum on. If it runs, place palm of hand against inport hole. If it shuts off the problem is with either the control valve setting or the control valve assembly itself.
For cvs, turn dial on top of vacuum all the way to the largest dot, and try above test again. If that doesn't work, then it's the CVA. It needs to be cleaned or replaced, which is an in shop job. Fro repair, take it to the nearest Aerus Electrolux store. I recommend a full clean and service to remove any dust/dirt from the motor, fan assembly, and other internal parts.
Another problem, which relates to the dial setting, is that fine dust will quickly clog the pores of the bag, resulting in the machine "thinking" the bag is full. Turning the dial to the proper setting helps get the bag fuller. The middle setting is the normal setting, and is for areas without fine dust and sand.
Dec 05, 2010 | Electrolux Vacuums
After using the unit for a few minutes it cuts off.
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
DOES A DYSON HAVE AN AUTOMATIC SHUT OFF VALVE
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
It cannot be reset manually.
Apr 07, 2010 | Dyson DC07 All Floors Bagless Upright...
Works intermittenly
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a DC 17. In the middle of vacuuming the vacuum stopped working when it was in the upright position. It only works when the head is down and i am using the bar. I can not use the extension bar,...
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC17's main suction motor is protected by a thermostat which shuts the machine down if it starts to overheat. This could be due to a blockage, and the filter may also need a wash. If this occurs, the separate brush bar motor will still run if you recline the vacuum, and shut off when you stand the vacuum upright.
The vacuum should reset itself automatically after it's cooled down for around 2 hours. To prevent this from reoccurring, please wash the filter as shown in our video guide - in normal use this should be done at least once every 3 months. Use cold water without detergent, and allow the filter to dry completely for at least 24 hours before replacing it.
Once you've done this it's important to check the vacuum for any blockages - our Support guide will walk you through each checkpoint to make sure nothing is missed: http://www.dyson.com/support/dc17/dc17-allfloors/diagnosis-root-menu/dc17filterwashvid/flo-dc17-wand-suction
This should resolve the issue. However if the issue reoccurs when the filter is clean and there are no obstructions in the airways, there could be an issue with the cyclone pack itself. If this is the point please contact us directly, as we'd appreciate the opportunity to provide further assistance. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction
hi!!! clean motor blower blades ,they collect alot of duct and the air in chopped,Good luck.Clean blower fan blades..
Feb 04, 2009 | Electrolux Centralux Vacuum
Problems with 353 nutone
if its an older unit or it got heavy use it could be the motor they tend to sputter as there going out, as it rotates the electricity hits a burnt spot inside the motor and shuts itself off can you turn it on manually? they usually put a swithc on the tank itself if the problem doesnt occur when you switch it then it could be the hose itself normally they control the off/on use a meter to check the continuity beteen the two copper plates that are on the end of the hose ( the wall end )
Sep 16, 2008 | Broan-NuTone VX475 Bagged Central System...
Vacuums Logo
91 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
