Question about HP LaserJet 3330 All-In-One Printer
Adriatik my problem is when the printer finised whit scaning everything is ok but after 2-3min printer start tu check scener when the strange sound comes from the scener and it goes to the right all the time
  • HP Expert
  • 141 Answers
Can't find home position. either the scanner assembly needs to be replaced, or the engine control board is defective. my guess is scanner assembly. good luck!
Posted on Sep 20, 2008
Dishwasher making strange noise
Check the spray arms for clogs..
Mar 30, 2014 | Dishwashers
My HP PSC 1210 does everything except scan. The
try scaning from computer. i mean dont press the scan button -on printer but rather use some application on your pc to start the scan. you could test with office document imaging software.
Regards
Feb 13, 2010 | HP PSC 1210 All-In-One InkJet Printer
The television has no picture and no sound and everything is connected. What could it be?
Good Day..
Let's see...
do you have your TV connected to a power supply?
How long have you had you TV?
Have you ever change the lamp?
does it make any strange sounds?
you give me little information!
lets see..
if it's just doesn't start is the LAMP!
http://www.discount-merchant.com/SearchResults.asp?Search=WD-52725
if it make a click sound on the back or like strange noises then is the color wheel!
http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsung-cw-bp96-01854a-enc.htm
and about the sound. may be the analog board that is the one that controls the sound or maybe try to clean your TV whit compress air
http://www.discount-merchant.com/1068982-HL-P5063W-p/1068982.htm
Jan 03, 2010 | Samsung HL-R4667W Rear Projection...
A/c blower not working
Check fuses and relays (refer to the owners manual for location). If everything checks OK, take a test light and check your wires leading to the blower motor to verify you're gatting power. If so, replace the blower motor. If no power to motor, your problem will be in your switch.
Jun 10, 2009 | 2000 Nissan Maxima
Everything works ok except strange hum and no heat
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
If it is under warranty you are golden. If not, you should get an estimate, as many new microwaves are now in the 50 dollar to 99 dollar range
May 21, 2009 | LG LMV1650ST Microwave Oven
No responce from accelartor after brake peddle is pressed
If check engine light is on get the codes pulled.
Jun 04, 2017 | 1996 Audi A4
Epson Stulus photo 820
A very strange effect new to me (and I'm ****** old). All I can suggest is to uninstall the printer, reboot and reinstall. Report back.
Apr 06, 2008 | Epson Stylus Photo 820 InkJet Printer
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
WON'T SCAN
Did you have things apart far enough to mess with the scanner.  The scanner should move to one side when it first goes on, and then trip a sensor (home position sensor).  Also, the scanner is probably belt or cable driven.  Check to see that the belt is somewhat tight, and that the gears and pulleys leading to the scanner motor are in place and not broken.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
HP LaserJet 3330 All-In-One Printer Logo
21 people viewed this question
Ben Johnson
