Question about NetGear DG834G Router
The Wireless Signal keeps dropping out.
This router (Netgear DG834G) used to work fine. Recently the wireless network has started dropping out without warning and often the internet connection speed can be very slow (sub dial-up speeds). I have checked the ADSL download speed using an older wired router and speed checking software and it's fine.
When the wireless drops out (which occurs on my laptop, PS3, Wii and iPhone) the light on the front indicating a Wireless transmission is still green. The network than randomly reappears and sometimes I can reconnect to it and sometimes I can't. I have read lots of sites trying to resolve this issue myself but to no avail. PLEASE CAN YOU HELP?
I list below what I have done/tried:
I have not added any new electrical equipment.
I have updated the Firmware.
I have checked the Firewall settings.
I have manually entered the DNS stipulated by my IPS (Virgin Broadband).
I have checked the local wireless routers and set my channel to 13 to deconflict from others (I set it to 1 and 2 as well but this didn't solve the problem).
I have de-powered and repowered.
I have returned the Router to factory settings and set it up from scratch.
I have checked my incoming internet connection using a wired router.
I have a WPA PSK enabled network in place.
  • Anonymous Sep 06, 2008
    yeah signal keeps dropping out. do i need a new one?
Thanks for your help Gepax - Strayjagmate.
Posted on Aug 26, 2008
  • 89 Answers
Make sure that there are no cordless or wireless devices near the router such as a cordless phone since that will interfere with the wireless signal and a cause for frequent disconnection.
otherwise, the device should be replaced already.
Posted on Aug 24, 2008
SOURCE:
Cant_conect__to_wireless useing netgear dg834g
try to reboot your netgear router. if the same issue persist, try deleting the wireless networks saved to your computer and try to reconnect.
Hope that works.
regards
Oct 20, 2011 | NetGear DG834G Router
Netgear DG834G router dropping internet connection
You could try a firmware update, if this is no better it may be time to ask your ISP for new router.
Aug 01, 2010 | NetGear DG834G Router
I cannot get wirelessconect to my laptop from my netgear modem router DG834G.I can see the signal but unable to connect
check whether the dhcp option is turned on in ur wireless router. if its turned off, change it to on state and try. u will be able to connect. still if u din get access. use some other lap to connect to ur wireless network. if it is possible to connect with someother lap, then the problem is with ur lap. the wifi drivers might get corrupted. re-install it to fix the problems. if all above doesn't gets work, then the problem is with ur wireless router.
Jul 21, 2010 | NetGear DG834G Router
My laptop won't connect via wireless, and can't even find the network. It used to work fine until a few days ago. I have a netgear DG834G router
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
May 08, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
Hi I have my desktop connected fine through the yellow cable, but need to know if I can connect my laptop wirelessly? if so how. sorry if question sounds silly but new beginner!
From ur laptop click "Start" then "Connect to" then "wireless network connection" then "view wireless networks" Your signal is probably the strongest one. Double click on it and it should aquire the network address automatically. Your in business!
Feb 28, 2010 | NetGear DG834G Router
Toshiba Laptop builtin wireless modem can't find any network
If the laptop is 3 years old then it probably requires a chipset update. Goto intel's website and use the driver update utility. If this does not work then your wireless connection may be broken. You can buy a wifi USB card for less than £10 if you shop around. Good luck
Jul 23, 2009 | Computers & Internet
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
NetGear DG834G Router Logo
1,785 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
