Question about LG Cell Phones
LG VIEWTY PHONE KEEPS TURNING ITSELF OFF FOR NO APPARENT REASON. ANY IDEA'S?
    Brigadier General:
  • 7,752 Answers
The boot up is corrupted so you need to tke the phone to a mobile shop and have them reflash the phone.
Posted on Aug 22, 2008
SOURCE:
Well my lg rumor touch randomly shuts off by itself then back on by itself for no apparent reason
with the phone powering on and off by itself that does point to a device issue, which needs to be replaced either through warranty or insurance
Oct 08, 2010 | Cell Phones
My lg viewty turns itself off whenever I or anyone
check that the memory card u use is not a cheap one you get such as carphone warehouse's version -_-' if u have a branded one such as san-disk then its most likely a fault with the phone itself, i have had the same problem, i replaced the battery and put in on charge for a full two nights and it worked fine.
hope this helps =D
Oct 02, 2009 | LG KU990 Viewty
LG Viewty KU990 - mine keeps switching itself off and then won't switch back on - any ideas please??
I think your battery is running out of power so
recharge it and wait for 1 or 2 min.
If not then you've to replace the battery.
I hope this will help.
Best regard:
Henk®Muskita ©2009.
Aug 06, 2009 | LG KU990 Viewty
Lg viewty phone keeps freezing when i click on my
hi
my hunch is that the my files is located on the Memory card and the memory card is faulty try removing your memory card and accessing your 'My Files' if this works then you may have to replace your memory card
cheers
pls rate if this works
Jul 13, 2009 | LG KU990 Viewty
LG viewty switching itself off and not restarting until battery removed and replaced LG Viewty randomly switches itself off and won't switch on again until battery has been removed and replaced.
I have exactly the same problem! My Viewty just switches itself off whenever I send/receive text/calls. I can't even switch it on anymore without it turning itself off after less than a minute!
I have contacted LG, but they are not responding. Has anyone found a solution to this problem?
Nov 20, 2008 | LG KU990 Viewty
Lg viewty vs samsung tocco ??????
hi, i work in the mobile industry and own a tocco myself. I would say that for looks the tocco is best but the camera can be slightly fuzzed. The viewty has had reports of software problems but im sure these are quite easily fixed. As per the touch screen, the tocco is more sensitive so is easier for texting but it is heat activated so cant be used wearing gloves or with a stylus, the viewty for the touch screen does need slight pressure applied. Widgets are actually available on the viewty as well, can just be a bit tricky to activate them. Obviously the tocco is much slimmer and lighter. All in all though i would say that samsung is a more trusted make, with less promblems occuring. Why not look into th new LG renoir and The samsung Omnia, bit more expensive but im sure they will have just the features and looks your after and the software is more updated. Hope i have helped!!.....J
Nov 11, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Phone keeps turning on while charging
its not a problem to charge your phone in "on" state.... you will get "charging full" notification even in "on" state
Sep 26, 2008 | LG KU990 Viewty
Apparent software problems
you need to have the phone reflash so take the phone to a mobile service center and have them fix it for you.
Aug 08, 2008 | LG KU990 Viewty
It keeps turning off
In the manual p76
Is your Secirity Lock turned on?
to disable - Settings - Security - Phone Lock - Autokey Lock
Apr 06, 2008 | Motorola Mobility W375 Cellular Phone
Sony Ericsson K610i
master reset once keeping the backup of ur phone ... and also format the memory card also once ...
Dec 18, 2007 | Sony Ericsson K610i Cellular Phone
Cell Phones Logo
66 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
