You need to get a digtal voltage meter (about $15) and check it out yourself-readings at the battery should be 12.5 volts after sitting overnight. Once you start it, the readings at the battery terminals should go up to almost 15 volts when first started, then gradually drop down to around 14.2 volts-I would bet either your battery is bad, or your battery is bad and your alternator has failed trying to supply power to a bad battery-either way, your mechanic should not have allowed the battery light to stay on after changing out the alternator without finding out what was wrong-he did not fix it.
