Question about Sony Playstation 3 (PS3) Console
2 disks stuck in ps3 - Sony Playstation 3 (PS3) Console
  • Anonymous Oct 23, 2008
    i need a ps3 disc drive blue print to put it back together HELP ME
  • p32parker Feb 07, 2009
    my 3 year old put 2 disks in my ps3, is there a solution other than send it out for repairs?
You are A ******, try beating yourself with a hammer
Posted on Jan 06, 2009
Http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
pull the blu ray drive out, the ribbon cable lil black thing pulls back like a lil door to put the ribbon cable back in. peel off the dust sticker and use a flat screw driver to wedge out the disks. a friends kid stuck 3 disks in her ps3. but i got them out it works good now. oh yeah since you have it open use the compressed air can to blow out the dust.
Posted on Jun 16, 2009
    New Friend:
My kid put 2 disks in my ps3. Very easy fix. All I did was turn on ps3 and then insert a third disk but not all the way. Keep holding onto the third disk and with your other hand you press the eject button. When you push the eject button, pull on the third disk slowly. Both disks will come out with it.
Posted on May 08, 2013
    New Friend:
U lot need to shoot yourselves in the head
Posted on Apr 09, 2011
4 disc stuck in ps3 disc drive .we got them out but cant put disc drive back together properly . i need a blue print
Posted on Oct 23, 2008
    Sergeant:
  • 243 Answers
Youd have to open up the drive and remove the disks.
Posted on Aug 22, 2008
SOURCE:
PS3 stuck on red light after it froze up. I unplugged it and replugged it and it's still stuck on the red light. It doesn't change or anything even after hitting the power button.
It would help, if you posted the model number of your system, as they do vary sightly. Is there a disk inside they system? This could be the main problem in witch there are several solutions to remove it. If not, than try inserting a disk, as the PS3 auto recognizes a disk being inserted and turns on the system. If the light is on, and it wont let you power it on, then generally it's the stuck disk problem. ^^ Hope this helps, and good luck.
PS3 Slim Manual Eject for Stuck Disc
Sep 23, 2015 | Sony Playstation 3 (PS3) Console
Problem need help
There are several videos on youtube about how to remove stuck disks. I'll post 1 for you here.
How to remove stuck discs in your ps3 first generation
Jan 17, 2014 | Sony Playstation 3 (PS3) Console
The PS3 will not open. I think disk is stuck
you would have to crack open the shell, but first try to use a butter knive this has happend to me before and you just have to guild the disc out a little bit Don't use games with the foil sticker in the center that you rent, they mess the track up
Jun 03, 2010 | Sony Playstation 3 (PS3) Console
I can't get the disk to eject.it's stuck in the ps3 and i can't turn it on or get the disk out! The led light keeps blinking on the ps3 and also on the controllers!!!
Look around your PS3 disk drive, depending on the type of PS3 there might be a small hole in which you can fit an a straightened paperclip. If there is just put in the paper clip and push until your cd drive pops out a bit.
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
Hi,my ps3 is saying, the hard disk's file system is corrupted and will be restored. the it says press ok. after i press ok, then it says restoring the system, after that it restarts it goes back to the...
here's some ideas:
________________________
I fixed my ps3!! All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
_______________________________________________________
I tried to fix my friend's PS3 HDD that way in mine...it still gave an error every time he booted up his PS3. At that point I stuck the PS3 HDD in my laptop, booted from a Windows CD and fully formatted it that way...stuck it back in his machine...used it to format....finally got his stuff going. Took a little extra time but no problems since.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
Theres a game stuck inside the machine and no game icon appears on the screen indicating i can load
Have you recently picked up or moved your PS3 console and carried it? The disk may have fallen out of the slot in the PS3 causing it to slip INTO the ps3.... This may be a serious problem and you may have to open it up to retrieve your disk, otherwise SEND IT IN!
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
I have have a game disk that doesnt want to come out its stuck in
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=1193&p_created=1218491832&p_sid=-8Jmf9vj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MiwyJnBfcHJvZHM9MCZwX2NhdHM9MCZwX3B2PSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWZvcmNlIGVqZWN0&p_li=&p_topview=1
read this lnk, hope it helps
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Blue Ray disk stuck in PS3
keep the power or the elect button pressed for 20 secs. this will trigger the disc to come out i think.
Mar 25, 2009 | Sony Playstation 3 (PS3) Console
Disk error
have you try to clean you disk and the disk reader ?
Aug 12, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,285 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
