Question about Cell Phones
Unable to create a bluetooth connection even after pairing up and putting in correct code.Sometimes has worked after shop altered settings then for some reason stops connecting to either bluetooth earpiece or in built car system.
  • mail651 Aug 22, 2008
    A flippant remark which does not warrant any further communication.
    Brigadier General:
  • 7,752 Answers
The best suggestion is to buy a new one
Posted on Aug 22, 2008
I also trying to pair my galaxy s5 and all it keeps saying is pair failed and on the parrot it says pair your phone P
Sometimes the bluetooth of different devices will simply refuse to pair, it's an old, known problem to which there is no fix.
Just use another older phone.
Nov 24, 2014 | Cell Phones
Toshiba tv what is a pairin coad
A Pairing Code is generated by the originating device which must then be typed into the second device in order to protect security of devices. Usually a xxxx 4 digit number is used. It appears on the first device when setting up the Bluetooth connect for the first time.
The Bluetooth is put in discovery mode & then creates a random Pair Code when it discovers another connectible device.
eg. You use Bluetooth headphones to Pair with your iPhone. The code is usually 0000 for simple devices.
If you want to Pair your iPhone with your Car's Radio/Amp then you go through the pairing routine to match the two devices.
But you don't want the guy next to you connecting his music into your radio so he is required to "Pair" first
Was This Helpful?
Then tick the box!
Jun 29, 2014 | Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
My htc hero pairs but then says paired but not connected. It cannot then be found so i cant send or receive any thing through bluetooth also the phone dosen't connect wirelessly 2 my livebox (orange...
The Hero has a rather crippled Bluetooth which is one of the reasons I'm sending mine back.
For security, when you set the phone to be discoverable it only stays that way for 90 seconds. This cannot be altered unless someone works out how to bypass it with an app but I understand from HTC that this feature is built in at the firmware level.
Look down at the devices list in the Bluetooth menu and you'll see what's paired with the phone; press menu and you'll have the option to connect.
Bluetooth on this phone cannot be used for file transfers of any kind. It's only there to enable connection of devices like headsets and external keyboards and that's about it. You can't even take a photo and Bluetooth it to another phone. There is no way around this at present.
Not connected with your question, but have you discovered the annoyingly expensive and non-alterable trick which it does when you want to send/forward long SMS messages yet?
Oct 07, 2009 | HTC Hero Smartphone
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Cell Phones Logo
121 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
