Problem with Canon Copiers
Error code e000732-001 on a canon ir 8500 what it
1 Solution
Error code e000732-001 on a canon ir 8500 what it means
Copiers Logo
493 people viewed this problem
  • 2 people found this problem to be helpful.
  • 2 people are following this problem.
More Insights on Fixboard
1 Solution
This solution has been voted best by the Fixya Commnunity
The error code e000732-001 is a communication error between the Scanner and the main unit. Most of the problems are caused by the interface cable comming lose. Always make sure the unit is powered off before attempting to unplug and replug back in. Look to make sure this cable has not been damaged in anyway. You do not need to go into service mode to clear this error. It will self correct once cable signal is re-established. It is possible to be a bigger problem but as I outlined stick with the simple steps first. Good Luck.
2 Suggested Solutions Relevant solutions from other related problems that we feel might be a fix.
Author image
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Source: canon ir 8500 error code 001-010 and E 001-003
  • Was this solution helpful? Yes No
Author image
eo 732 is a reader board error or a bad or missing connector from the scanner to the machine looks like a parrallel connector
Source: ERROR IN IR 8500
Add your solution
Full Name
Top Canon Copiers Experts
Canon tech CROATIA
  • Solutions: 1219
  • Level: 3
  • Achievements: 1
Chris Coughlin
  • Solutions: 1218
  • Level: 2
  • Achievements: 2
Paul Pettit
  • Solutions: 270
  • Level: 2
  • Achievements: 1
Expert Badge
Are you a Canon Copier Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More Copiers Related Problems
Unsolved Problems:
Loading... Loading...
