Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
98 fatboy engine noise.
My 98 fatboy starts & runs fine for the first 10 min. after it heats up it makes a whining noise that seems to come from engine, but stops when bike is stopped & in neutral. also seems to be running hot!
  • 1 more comment
  • brad groffen Aug 25, 2008
    could this be caused by oil overfill or oil screen plugged?
  • brad groffen Aug 26, 2008
    tks, I'll let you know how it worked out.
  • brad groffen Sep 02, 2008
    tks for the help guys.I checked the screen & it was fine. I drained some of the oil (motor) and that seemed to do the trick! must have overfilled it my last change.(a lot) ever heard of this happening before ? & if so, why?
1)Check for a change in your primary drive area? 2) Oil levels, drive chain tensioner loose? 3)Pehaps the oil pump itself is worn.
Posted on Mar 11, 2011
I had the same problem on my 98 fatboy...I had the rear tire changed because of wear and the belt was tightened and when I got the bike back the whinning was gone
Posted on Sep 25, 2008
No noise when cool but wines after warm up, only while rolling and not wining stopped and in neutral. transmission is the first i would check. if it was the cam, it would make noise when the engine is running and i do not think it to be the primary since it spins when the engine is running. i would definitely drain and flush the transmission and check for metal. a bike this old will have some flashing but not an excessive amount. harley transmissions are not the best and they will usually wine or clunk but that doesn't mean it is bad. i would say that you are getting a little wear such as spacer shims which will allow more play and wine. do not run engine oil in the transmission, run mobil one gear oil or the harley transmission oil. engine oil does not have extreme pressure additives. if you hear a wine with a little rattle with it, better start checking the bearings. oil screen plugged???? i have been running hd since the sixties with over 150k miles on some with no overhauls and never had a oil screen plug up. if you do proper maintenance this should never happen.
Posted on Aug 30, 2008
    Genius:
  • 2,028 Answers
Harley's do run hot, anywhere from 220 to 240 normally, and a little hotter this time of year. I suggest running a straight weight oil, and a little heavier weight in the summer. I use Valvoline VR-1 30 weight most of the year, and 50 or 60 weight in the hot summer, and I use Lucas 20w50 primary/trans for the primary and tranny. I don't bother with the extremely high prices of the HD oils. For the whining noise, you need to determine which side of the engine it's coming from. Whining will almost always be in the bottom end. There's nothing in the top end that should whine, and if there is whining from the top, it's usually an air leak around the carb. Start by checking the fluid levels in the tranny, and primary. These are the two most common areas to pick up a whining noise. If it's coming from the left, it's going to be in the primary, and usually this is caused by low fluid levels. From the right, it's going to be either the tranny, low fluid, or the oil pump. The oil pump is a gear type system. If you're running a light weight oil, say a 10w40 or HD 20w50, when the engine heats up and the oil thins, it can cause the oil pump gears to whine a bit, especially in the summer heat. So, check the fluid levels, if they check good, then change the oil, since the summer is coming to an end, go with a straight 30 weight. This should clear up the whining noise. If it doesn't, get back to me with the exact location the noise is coming from, and we'll go to the next level of diagnosing the whine, but I believe that this will cure it.
Posted on Aug 22, 2008
  • Ryan Rogers
    Ryan Rogers Aug 25, 2008
    It doubtful that overfill would cause it, the engine will generally purge the overfill. The oil screen being plugged or partially plugged could cause it. The oil screen that is on the right side of the bike, under the screw, appears to be in the cases, but it's actually in the oil pump. If this screen is clogged up it decreases the flow of oil through the pump,and could cause the gears to whine a bit. I clean mine every oil change.
  • Ryan Rogers
    Ryan Rogers Sep 02, 2008
    Never heard of it!! I overfill mine a bit every time, and never had a whine. The only thing I can think of, is that the overfilling has created a little more back pressure than usual, and is creating a little extra pressure on something (probably the oil pump gears) You might check the blowby assembly on the heads. If the tubes are gunked up, or the hoses have collapsed, it could be partially plugging the blow by assembly and not letting the back pressure escape properly. Just take it off and clean it with carb cleaner, and replace any rubber hoses. I'm running a
    Super E on my bike, have T'ed off the blow by, and run it out the bottom of the bike, instead of through the air filter. I change out the rubber hoses every other season to keep from getting a collapse due to dry-rot.
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
Hi my c1 has started to make a whining sound (bit like a dog whine) the last couple of days. It tends to get louder and is intermittent, it starts when the engine is fired up (no probs starting engine)...
Have your drive belt replaced (sometimes called the auxiliary or serpentine belt) when it slips it creates a screeching noise and it's also a sign that it's going to fail (snap).
These can run the alternator and power steering so you should change it as a preventative measure.
Oct 17, 2013 | 2008 Citroen C1 1.0
I have a hero honda karizma 2005 model and bike stops after running for 10 kms... i have changed the battery, new chains, new spark plug also done
make sure u gittn proper cooling -is it water cooled--the heat will fry engine soon and also heats up wiring and components so they stop workin--getta clymer manual or a bettr mechanic--ur loosen money on rong solution
Feb 26, 2013 | Motorcycles
93 s10 whines
The fuel pressure regulator & spyder assy, most likely is bad
Don't think that is your noise though
Check trans fluid,may be pump noise
Jan 06, 2013 | 1993 Chevrolet S-10
2007 Honda Elite 80 rear whining noise
Hi, Keith, I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
www MajestyUSA com
new to me 2002 Elite 80
Honda CH80 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
31GV4770 2006 Honda CH80 Elite Scooter Motorcycle Owners Manual Paperback... $20
Mar 26, 2012 | 2007 Honda Elite 80
I have a kenmore 90 series dryer model 110.60922990. It makes a funny noise while running for a few min. After about 10-15 min it shuts off and will not restart immediately, I have to wait for a few min...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 06, 2011 | Kenmore Dryers
99 Sportster,Custom. Starts & runs great, get
Okay one issue with many of the Sportster models is the intake gaskets. They only seem to have a life of two to three years. What happens is once the bike gets warm these gaskets don't work well if very much at all and the bike is too lean to start. But once the bike cools off all is good. Sound familar?
Now I've personally owned a 1978 XLCR, 1984 XLH, 1997 XLCH, and each and everyone has made me cuss with the same issue.
You may have other issues but I would start there first, as the gaskets are less than $10, the labor if you do it yourself is free. Good luck and let us know if this helps.
JP
Oct 18, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Lands Phones Logo
1,269 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
