Question about Canon PowerShot SD100 / IXUS II Digital Camera
Focusing Difficulties Sometimes the camera can't get a good focus on some objects. Whats can I do?
    Sergeant:
  • 255 Answers
1. Typical problem subjects for autofocus 1) Very low-contrast subjects 2) Overlapping nearby and distant objects 3) Very bright subjects in the center 4) Subjects moving very fast 5) Subjects through glass Focus on an object that is at the same distance as the desired subject, apply Focus Lock, and then recompose the picture. Or set the lens focus mode switch to (or), and focus manually. (Manual focus is only possible with cameras providing this feature.) 2. Attempting to take pictures out of the camera's shooting distance: When taking pictures out of the camera's shooting distance, the subject will be out of focus. The shooting distance differs from each camera model. Please check the specifications of your camera in the instruction manual to determine the shooting distance.
Posted on Aug 29, 2005
SOURCE:
When recording a video zoomed in how do you get the camera to focus on the object ?
Focusing is one of the most difficult parts for every digital camera. Special on the end of the moon, and if the lights are low. Every camera needs sharp contrasting backgrounds and no distracting other high contrast objects in the foreground.
Be aware when you soon in to the end of the zoom range, you can't focus on close objects. Minimum focus distance can be a few meters.
It could be you switched to silence the focus noise, what can be bad for focusing.
See what the manual is telling you about zoom and focus:
Read the manual again, and check what settings would be the best for you while shooting video with a long zoom setting.
Here is the manual:
http://downloadcenter.samsung.com/content/UM/201405/20140522111801989/WB1100F_UM_English.pdf
Jan 03, 2015 | Samsung Cameras
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
How do I take clear pics of xmas lights so they are clear
The camera is having problems focusing. Try focusing on a bright object hold the shutter button half way down to lock the focus then frame your image and press the shutter to take the photo.
If this does not work then try manual focus.
Dec 11, 2012 | Kodak EasyShare C653 Digital Camera
Compact digital camera; zoom blur images. what am I doingwrong?
You may be doing nothing wrong, however the camera is either having trouble with the focusing circuitry/lens assembly, or you're not holding the camera still enough, with a solid focusing object (not likely, but happens). I suspect that some aspect of the focusing circuitry (while zoomed) isn't functioning. While that can be a microprocessor problem, it's rare and not likely. Most likely there is debris (dust, sand) in the lens assembly, and needs to be blown out with compressed air. If that doesn't work, you can try to zoom, then hold the camera with the lens facing up, and bump it gently with the palm of the hand, on an area without switches. The focusing ring inside the lens assembly is sometimes stuck, or jammed by debris, and can be freed by compressed air. Bumping the camera tries to reseat the focusing ring, so that it works correctly, from the cpu signals, and focusing detector. If these suggestions don't work, it will have to be serviced. Make sure you get an estimate first- the cost of repair often exceeds replacement cost of a new camera, on sale. Good luck!
May 20, 2010 | Kodak Easyshare M580 Digital Camera
Problems with kodak v1073 focusing, my camera tries to focus on an object and you can hear it focusing, but it is a 50/50 chance of getting a clear pic.
E-mail your question to Kodak at: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 06, 2010 | Kodak EasyShare V1073 Digital Camera
How and When to use AUTO FOCUS and MANUAL FOCUS of my contax t2 camera?
There are no rules or conventions for this. It is totally up to you to chose which method to use.
Sometimes when taking images in close up where a leaf or stalk may invoke autofocus to lock onto the wrong object to get a clear pic, then select manual so your subject is in focus
Depth Of Field is also associated with focusing, autofocus does not always deal well ith DOF situations. It might be better for you to get a simple book on digital photography to help you understand how to get the best results from your camera
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Contax T2 35mm Point and Shoot Camera
I need instructions for minolta freedom zoom 70 exI want to know what macro does.
Hi. As a pro photographer, I can tell you what 'macro' does on all cameras or lenses. 'Macro' focusing is for focusing on close objects, say an inch or two from the lens to a couple of feet. It is for closeup shots, say ants, or a fly, or someone's eye, raindrops on glass, etc. Try it out sitting on a patterned countertop or table or tablecloth to give you an idea, focusing far away and up close.
As far as the manual, there doesn't seem to be anything on the official site unfortunately. Good luck and have fun.
http://gi.konicaminolta.us/index.asp
Apr 14, 2009 | Minolta Freedom Zoom 70 35mm Point and...
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Canon PowerShot SD100 / IXUS II Digital Camera Logo
347 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
