Question about Insignia NS-PDVD8 Portable DVD Player
Wrong region Hi, In setup prefrence option is disabled so i am not able to change region code.
I have no power with the rechargeable battery pack or the plug
Posted on Oct 20, 2008
I Can Not Find a YAMADA DVD-7600XTV Region Unlocker
I don't know if this will work but I can atleast try to help
1) Open the disc tray.
2) While the tray is open, enter the following code with the remote's numeric pad: 2812
3) To change the region code, press the "Enter" button repeatedly. "Region 9" means all regions will be enabled.
4) Close the tray to save the desired setting.
Other Zoran Vaddis 776 based players have other options on this screen (such as Macrovision Enable/Disable) but this player only offers the region code setting (note the unused available space for other menu options).
If you press "Display" on the remote, the firmware version will be displayed.
or
1. Press "Eject"
2. Press "Setup"
3. Press 3x on the right "Präferenzen-Setup"
4. Press 7x Down "Land"
5. Press 1, 3, 7, 9
6. And 0 for code free
7. Press "Play"
Mar 29, 2009 | Yamada DVD-5520 DVD Player
Tip
To view all region dvds
Model - MCD289 - Turn system menu to prefrence page - insert the following code 811502 - then change region to zero - all region dvds can now be viewed
on Apr 20, 2009 | Philips DVD Micro Theater Shelf System...
Navman S reset
Please go to Preference option on your navman. From the main screen you can setup the following preferences.Now scroll to 3rd page of the prefrences.There you will see the following options:
  • Start Up – enable/disable the tutorial and language selection screen that appear when the system is switched on.
  • Saved Info – here you can delete recent locations, favourites, avoidances and reset to factory defaults.
  • Bluetooth – this option allows you to setup bluetooth pairing with a mobile phone.
  • Tutorial – run the tutorial that appears at startup.
  • Shop Demo--runs a demo so you can see the Navman S50 in action.
Just select the SAVED INFO option and then you will see a RESET TO FACTORY DEFAULT OPTION.
Jul 23, 2008 | GPS
Navman
Jul 23, 2008 | GPS
DVD8723UK
this region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Jul 11, 2008 | Digix HT1056A DVD
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
Multi region code
This is not possible without bypasssing/cracking the firmware on your DVD player. your player will generally allow 3 changes to the region code. If you have not changed yet, you may do so within the DVD player's setup options.
Go Video Unlock Code
check the menu settings or (setup) on the dvr 4000 to see if it has options to enable or disable parental lock or to change region settings to region 1.
also the dvds you made are they +r or -r on what brand dvd record disc on dvd-r this may solve the problem but use a quality brand disc like memorex dvd-r it is compatible with many players and recorders also make sure the disc you made on the recorder were finalized.
Jan 03, 2008 | GoVideo Go Video DVD/VCR Combo
Setting region codes to code 1
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
Oct 18, 2007 | Pioneer DV-373 DVD Player
Insignia NS-PDVD8 Portable DVD Player Logo
42 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
