Question about HP Compaq dc5100 PC Desktop
Beep 9 times red light on - HP Compaq dc5100 PC Desktop
  • HP Master
  • 3,051 Answers
I am thinking this is a 3 beep followed by 3 beeps followed by three beepsss right my dell did that too and it turned out to be a memory issue i was trying to use a 128 stick in it and it couldnt use it so i went and got 2 256 sticks and put it in and it works fine now
Posted on Aug 22, 2008
9 time beeps
Posted on Feb 22, 2010
HP Compaq 6005 Pro, nine beeps
9 BeepsNine beeps means that there has been an AMIBIOS ROM checksum error. Literally, this would indicate an issue with the BIOS chip on the motherboard. However, since replacing a BIOS chip is sometimes impossible, this AMI BIOS issue is usually corrected by replacing the motherboard.
Use utility tool like RegInOut to repair corrupt registry files and keep your computer safe from being damaged.
Jan 04, 2012 | HP Compaq 6005 Pro (NV513UTABA) PC Desktop
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
Spins, red light, many many beeps
look for 9 beep problem in FixYa
or see here
good luck
Apr 06, 2010 | iRobot Roomba 560 Robotic Vacuum
560 backs out of charging base then only turns in right circles
Yes, this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
Have fun
Dec 05, 2009 | iRobot Roomba 560 Robotic Vacuum
No menue just background when turned on
9 times out of 10 this is a hard drive issue. You can try removing it and reinstall. If your lucky! this will fix But most of the time you will need to do the following
1. remove all cd's,memory or anything you have connected to the ps3 on the usb's
2. turn on your ps3 from the back switch but leave it with the red light on(on the front).
3 now press the power button (where the red light is)and hold it, you will heard the initial single beep then you will hear a second single beep after that you will hear a double beep. when you hear the double beep release. You may have to do this twice cause it doesn't always work the first time
4. a menu with 6 option will appear. 1st rebulid file system and restart
If that doesn't work then try system update
Note: You'll need a flash drive with Playstations 3.01 update
Here are the instruction on how to do system update with flash drive
if that doesn't work you'll need to restore PS3, note this will delete all your data
Good Luck
Oct 23, 2009 | Sony Playstation 3 (PS3) Console
Red sensor
If your Roomba's red "check robot" light comes on, the Roomba should also give a hi-lo warning tone, then a number of beeps. Check the number of beeps with the chart toward the end of your manual-- it should tell you what to do.
May 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Ps3 says cannot start the correct hard disk was not found
try safemode
hold down the power button while the console is in standby. the light will go from red to will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Red light flashing 4 times, tv turns its self off
Start by removing and inspecting the bulb. The filament you're looking for is encased in the glass tube in the center of the lamp itself. Kindof difficult to see unless you're at the right angle. 9 times out of 10 that solves the problem. If not move on to the ballast, the small circuit board directly underneath the lamp housing.
Jan 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
HP Compaq dc5100 PC Desktop Logo
1,017 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
