This
usually happens when either the Float Valve in the bucket is stuck in
the UP position (if yours is so equipped. Jiggle it to get it to return
to the DOWN position.
If you humidifier's bucket is not so
equipped. It's usually an indication that the bucket was not
reinstalled properly, after it was removed. To check and correct this,
turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the
bucket and reinsert it, making sure that it fits "squarely" in the
bucket holder from Top to Bottom. Once installed, make sure the bottom
of the bucket is not tilted down in any way. Plug the unit back in and
turn the Master ON/OFF Switch to ON. If it was reinstalled correctly,
the bucket full light should have gone off and the unit will run as it
should, if the humidity extraction level is set low enough.
Hope this helped you to troubleshoot and solve the problem.
