Question about Excelstor Technology J880 Hard Drive
Problems with Excelstor Technology J880 Hard Drive?
I have a memory stick 2 G JOGR, nr 626DFCGG.
I cant write or change files in this disk due that the disk is write protected not and I can't remove the write-protection.
There are solution?
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 20, 2011 | Excelstor Technology J880 Hard Drive
How to make the J880 to slave
you can read the jumpersettings here.
http://dl.dropbox.com/u/599106/Festplatte%2080GByte%20Excelstor%20J880.pdf
The file is in german. Comments are in english. Use only the red framed settings.
best regards
Josch
Nov 14, 2010 | Excelstor Technology J880 Hard Drive
How to format excelstor hardisk?
For your specific operating system, assuming that Windows is running, locate Admistrative Tools -> Disk management.
You should see Disk 0 or Disk 1 with your Excelstor 80GB drive: if you do not have a partition, create one or more partition, assign drive letter(s) and then format using the context menu.
If you do not see the drive in the Disk Management screen, then your Bios has not been setup properly or your drive is not connected properly.
Hope it helps.
Sep 27, 2010 | Excelstor Technology J880 Hard Drive
I have changed hard drive to ExcelStor Callisto 80GB, and i can't update windows xp sp1 to sp2
What error-message(s) do you get?
Access http://www.microsoft.com/downloads
and download Windows XP Service Pack 3,
and install it.
You do *NOT* need to install SP2 before installing SP3.
Dec 26, 2009 | Excelstor Technology J880 Hard Drive
Cant install ubuntu 7.04 on Excelstor J880 SATA Drive
From what I know, both your motherboard and your hard drive work with Ubuntu. I would try the newest release, 8.04 (Hardy Heron).
Try setting the motherboard into AHCI mode rather than IDE mode (you should be able to change this under hard drive settings in your BIOS)
Also, the problem may be with your optical drive. Try swapping that out.  If you can't solve it from there, if you haven't already, try posting on the ubuntu forums.
Jul 26, 2008 | Excelstor Technology J880 Hard Drive
Internal 80gb harddrive excelstor j880
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
Excelstor Technology J880 Hard Drive Logo
288 people viewed this question
Top Excelstor Technology Computers & Internet Experts
Elise Lacoursiere
Elise Lacoursiere
John Anderson
John Anderson
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
