Question about Pioneer DEH-30MP CD Player
My aux wont recignise my ipod
How can i fix this could i b a fault with the aux?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
Possible, but if your iPod is playing through an aux input, it is just gonna be analog audio through a headphone jack. Basically, if you have sound through headphones, then you can pipe that into any source unit. What radio do you have (brand and model number)? some radios have menus that require that you first turn on "Aux" before you'll hear any audio through it. Depending on brand and model, some units have "Aux1" and "Aux2".
Posted on Aug 24, 2008
Engine over heating
I assume your Apple Aux adapter in your GMC Acadia is overheating. If so, the problem is with improper insulation or poor wiring in the center audio console. Ask your GMC technician to have a look into the insulation inside the dashboard and center audio console.
If the engine is overheating when you plug in Apple device to the Aux adapter, then it is the case of wiring fault that clashes with the engine's cooling fan circuit. Most probably some loose contacts inside the dash creating some ground or electrical disturbances.
A visit to the GMC service will fix this. Also if your GMC is still under warranty, you better do not do anything fixes on your own. Such un-authorized fixes could void the warranty and GMC can take it for granted for all future services that falls under warranty!
Mar 06, 2011 | Apple Gmc Acadia 2010 10 Direct...
My zeppelin has stopped playing altogether, ipod works fine, but no sound ... yes i have turned it up!
if the aux input at the rear works, then the fault relates to the docking arm or the interface on the back. (Does the ipod charge on the docking arm, have you tried another type of ipod, as different ipods have different connections through the arm!)
if the aux input does not work, then the main board/amp/pse could be an issue.
if the model is more than six months old it will probable have the known problem boards, so contact b and w servie and they should check it out.
Mar 02, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
No sound coming out
if the system is on, try a feed on the aux unit, if that works then it is the docking arm. there are faults on these units that b and w are aware or, they should fix the fault anf update the parts which are the cause of probels in all but the very latest models.
Dec 06, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
I would like to get my ipod nanos to work on my ubuntu operating system. I have just installed ubuntu on a friend's system and banshee does not recignise the ipod when I connect it.
- try using gtkpod for ubuntu, search for it and download it.
- once you got the package, open a console and type this in the command line:
sudo apt-get install gtkpod
Nov 03, 2009 | Computers & Internet
I dropped my On Stage micro and now when my iPod is docked and the on stage is powered on their is a LOUD buzzing sound from the speakers. The auz-in mini plug still transmits sound and music fine, only...
I have had then same exact problem, except I had an ihome. I've done research on it for a way to fix it. basically what I have come to find is that the plug for the ipod is just cheaply made, and that there is basically no easy and cheap fix for it. However as long as you have an aux-in you can just simply avoid the problem by buying an eighth inch to eighth inch cord so that you can just simply plug you ipod into the aux-in. As long as you have the ipod plugged into the the aux-in, and aux mode is selected, it should play your music while charging.
Sep 21, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Radio issues
make sure all systems are compattible check owners manual and ipod instructions some ipods just wont work with radios. hope this helps?
Aug 25, 2009 | 2006 Ford F 350 Super Duty
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Want to use ipod on cdx-f5710, how to fix it
use the aux lite input on the rear of the reciever. If it is a 3.5mm plug, you will need an extension with both ends male. One end in the aux port, on your head unit, the other end in the headphone jack of the ipod.
If it is RCA Aux lite, you need an rca-to-3.5mm adapter. Either item should be relatively cheap. $4-$5 USD
Dec 22, 2008 | Sony CDX-F5710 CD Player
HELP! ipod wont work.
Hi guys, just figured out how to hook up your Ipod to the above mentioned stereo, Here is how...
- Put your stereo in STBY mode, then push the menu button, scroll up or down and you get different options to change clock and AUX settings, my AUX was OFF and I had to select ON. Now you can push your Sorce button (the one that puts the stereo in STBY) and you will have the AUX option this will allow you to play your MP3 players and Ipods. ENJOY!
I spent a few hours looking for this very explination so I hope this saves the rest of you some time. Safe driving.
Aug 08, 2008 | Kenwood KDC-135 CD Player
Pioneer DEH-30MP CD Player Logo
280 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
