Question about Pioneer DEH-30MP CD Player
My Aux-in wont work
Please some one tell me how to work my aux in i tryed about 5 aux cables with my ipod and none of them show up on my head unit
  • Carly Jun 18, 2013
    Hi there I have one of these players and have been getting quite frustrated at the fact I cannot connect my iPod any help much appreciated
Did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Posted on Oct 15, 2008
I had the same problem with my Pioneer DEH-30MP I took it out of my one car and put into new car and the AUX would no longer work and you couldn't access the AUX menu as per the user manual.
To switch the AUX input on, switch the ignition on, switch the head unit off by pressing and holding the source button. Press and hold the source button for at least 5 seconds. Tuner will then come up on the display. Press the function button until AUX - OFF appears on display then use the arrow keys to select ON, press the source button to come out of the menu.
Then your done! just press the source button to change from Tuner to CD to AUX.
Posted on Aug 06, 2010
    New Friend:
I can't get mine to come up it was working earlier then turned it off and was playing around with the bass and now the aux doesn't come up in function menu just goes through all other entails but when you put a cd in it comes up like the aux used to any reason why? Or any way to reset to default setting???
Posted on Jul 28, 2015
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
I Can't seem to find the aux function on my Kenwood 50wx4 radio, any help please? I'm trying to hook up my ipod!
Most times you will have to put the radio into stand by mode, then go into the setup menu. There should be an option in the menu to turn the AUX to ON.
Oct 17, 2012 | Kenwood Car Audio & Video
Cant find aux conection for ipod function pioneer car stereo deh-p6800mp just need help trying to get ipod playing
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer http://www.google.com/products/catalog?hl=en&source=hp&q=pioneer+ipod&um=1&ie=UTF-8&cid=9877805020289826524&ei=_vPKSpzyKYe4NrzrpPMH&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
Oct 06, 2009 | Pioneer DEH-P6800MP CD Player
There is a auxiliary button on the sony cdx-m8800. Is there a way to hook up an IPOD? The stereo also has MP3 written on the inside face. Thanks
Contrary to the below Expert's testimony, the UK CDX-M880 has a REAR AUX connector that will enable you to play your iPod through your car's stereo.
You will not be able to control the ipod's interface through the radio. You will have to use the control on the iPod .
You require a Male 3.5mm extension cable like the following...
a5e60c6.jpg A 4-6 foot length is recommended, as the cable will need to be routed from behind the radio to a place your iPod can be easily manipulated.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 18, 2009 | Sony CDX-M8800 CD Player
Ipod worked with my pioneer deh-p3700mp before
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Dec 31, 2008 | Pioneer DEH-P3700MP CD Player
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Install
The ipod is supplied with a USB out cable and the head unit is USB compatible.It has a USB out.Connect the ipod "out "cable to the USB of the HU and switch over to USB mode on head unit. Switch on the ipod & play . As for erahs problem ,these pioneer head units have "switchable"AUX modes. with the power "off"(the HU power off)press the multicontrol at the centre for 3/4 seconds.options like "language etc will b displayed .AUX will be one of the options .select it ":on".now u can play your ipod through your head unit .
Sep 29, 2008 | Pioneer DEH-P80MP CD Player
How do I turn on the "external aux" for my pioneer DEH-p7000r
You'll need an adapter cable such as this one:
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=ip+bus&i=469PIOPRCA
The adapter cable will convert the changer port on your head unit into an AUX input with dual RCA jacks. Once connected, the head unit will detect the cable and allow it to be another source (i.e. radio, cd, aux).
To connect your iPod to the adapter cable, use any iPod cable or dock that outputs to male RCA plugs.
Apr 01, 2008 | Pioneer DEH-P7000r
Pioneer DEH-30MP CD Player Logo
2,365 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
