Question about Philips HTS3450 System
HTS 3010 -DIsk Tray
Dear Team...
I am having HTS 3010 Hometheater, actually its disk tray is not working properly, once open remains open...is this a system problem or else???
Waiting for ur earliest...
Thanks again....
Please switching on and off
Posted on Aug 22, 2008
Sony cfd 646 - cannot open disk tray
Some have a tiny hole in the tray front to manually release it/push the tray open.
Dec 20, 2016 | Sony Televison & Video
My philips dvd hts 3545 does not play the dvd says there is no disk. it could be a problem of region code. how can i unlock the region code to make all region code
hi,
you can make the player region free by the following setup.
1.TURN ON THE PLAYER
2.PRESS OPEN/CLOSE TO OPEN THE TRAY
3.WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6 in sequence
4.YOUR REGION AREA WILL BE DISPLAYED.
5.PRESS "0" TO UNLOCK ALL
6.PRESS "OK"
ok
Jan 26, 2011 | Philips Televison & Video
I have a 6 year old Panasonic DMR-50 and recently it has been displaying No Read on the faceplate and not compatible disk on the screen. I have tried both the Maxell and Memorex -R Dvd's and they both...
I found the problem and it was not a disk problem, instead it was a mechanical problem.
.Before you start taking the unit apart open the disk tray and unplug the unit, as the tray needs to be out of the way.
You need to take the unit apart to gain access to the top side of the disk mechanism. To do this remove the 3 phillips screws on the top back of the cabinet, on the side of the cabinet there should be 1 larger phillips screw on each side. Once you remove the screws you will have to work the top off as it can be tight. Once you have done this remove the face plate which is held be 3 plastic clips on the bottom and one on each side. When you have these released slowly pull the face plate towards you till it comes loose, on my unit all the connections are made with multi pin connectors that remain in place on the chassis and faceplate circuit board.Next you have to remove 4 small phillips screws from the top of the disk area. Once inside you should see a 2 piece plastic disk that has a small magnet in the middle and is on a flexible piece of metal that is underneath a piece of bent metal to limit its upward travel. If this plastic disk is loose carefully snap it back together by holding one finger underneath applying pressure with your other hand from the top. Check to make certain it turns freely and push down slightly on the metal to make sure it moves up and down. If it does now is the time to look inside with a flashlight and locate the laser lens, as this is the perfect time to clean it as suggested by someone on this board. Now put everything back together and unless there is a further problem in the unit you should be back in business.
This tip was given to me by a technician for Hewlett Packard who I was chatting with while traveling to the San Francisco area by train several days ago.
Linda
Jan 15, 2011 | Panasonic DMR-E50 DVD Recorder
Open tray comes up when loading a game?
Try tapping above the disk drive or if that doesn't work open the tray take your disc out close the tray. open the tray put ur disk back in and close the tray again.
Mar 15, 2010 | Microsoft Xbox 360 Elite Console - Black
Numerous probs: 1)door won't open/close (if it does open);2)can hear (intermitently) mechanisms working when equipment is off; 3)will not detect DVD
I would suspect a weak power supply. If the power supply is not giving proper voltage, or even able to maintain proper amperage, then numerous problems will occur. One of my Ilos would take forever to come out of the "Hello" screen or open the door to load, or once you got a disk in it it would not recognize the disk. You could hear this grinding noise coming from it. Any of this sound familiar? On mine the two large capacitors on the power supply board were bad. If they are swollen then change them out. Radio Shack had them when I did mine, but most electronic supply store should carry them
Jan 10, 2010 | iLO DVDR04
The disk tray won't open. this is brand
Just got mine out this morning. Googled this for two days with no success! Finally, out of despiration I took the screwdriver to the top cover. (four screws in the back, and two screws on each side) Lifted up the rear section of the cover which the released the front for removal. The input pc board is right on top of the dvd tray so little could be seen, so I removed the screws and clips holding the pc board. Make sure that you you disconnect the power before doing this however. Once you have removed the three screws, (two of which have attached grounding clips) you will need to disconnect the HDMI cable which plugs into the back of the board if you had not already done so. Now carefully plug the unit back into ac power, and while holding the board in your hand careful not to allow it to touch anything,press the open button on the front of the unit, and as you move the board slightly while pressing the button, the tray mechanism will start to try to release. Press the button several times till the tray opens completely and stops. Now comes the tricky part: Unplug the AC power plug while the tray remains open. (Otherwise the tray may close again and you'll have to go through the wiggle routine again to get it to open) Once it is open, remove the DVD Disk if there is one in there. OK, so now if you have followed these instructions so far the tray is open and empty, and there is no power to the unit, you can begin reassembly. Put the three screws and two clips back into the PC board loosely at first till you have all three started, then proceed to tighten each one. Replug the cable into the back of the PC board and then replace the top cover and the screws following the same procedure. Plug the unit back into the AC receptacle, and turn the unit on, then press the open/close button, and the tray should open and close as normal. I think what caused the problem to begin with is that I had left a DVD disc in the player for an extended period of time in the start play mode, and it either jumbled the programming or damaged the disc. I have not tried to put the original disk back in the unit to find out! I want to use it for awhile first! PS I would also suggest that onec you have it working, you might want to blow out the tray mechanism with an air cleaner spray.
Oct 24, 2009 | Toshiba DVR620 DVD Recorder/VCR
Disk tray for xbox 360 problem
try blowing in the xbox 360's tray in side where the laser or let it sit open tray for a little bit do things on it and then close tray it might work it does for my xbox most of the time im 12 yrs old
Jun 28, 2009 | Microsoft Xbox 360 Console
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Always opening disc tray
3 things cause this:-
A Damaged Disk, A Dirty Disk, or a Hardware fault.
Below is Microsoft's doc on the issue.
http://support.microsoft.com/?scid=kb;en-gb;816779
If my advice was helpful, please vote for me!
Nov 16, 2007 | Microsoft Xbox 360 Console
Philips HTS3450 System Logo
138 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
