Question about Ricoh Aficio 1018D Copier
Aficio 1018d hi, could you please advise me on how i go about putting the time right.
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'm going to mark this and look it up at work.
  • Ricoh Master
  • 2,794 Answers
Press the User Tools/Counter button.
Press System Settings.
Press Timer Settings.
Press the time button and make your changes.
Posted on Aug 22, 2008
Ricoh Aficio 1018D copies are light
buy a Photo conductor unit and then initialize it after you put new unit in.
Aug 14, 2014 | Ricoh Aficio 1018D Copier
How do i clean the dirty white plate in a ricoh aficio 1018d copier
Remove the exposure glass. The white plate is on the underside of the left scale. Clean with water or alcohol.
May 31, 2014 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018d toner not detected
oooh i think u need to replace devoloper gears there are five gears must be replacees. u need a tech. to do that
Feb 18, 2014 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018d sc 544
Hello!
This code is related to a Fusing low temperature error.
You probably need to change Hot roller (or fusing rooler) and thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do njot have technical knowledge)
If you still want to reset the code tey this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 03, 2011 | Ricoh Aficio 1018D Copier
I have a problem with my ricoh aficio 1018d copier. It is printing very faint. let me how to go about it
after every 60 000 copies the drum must change, if the drum changed inspect laser module and clean if dirt
Sep 07, 2010 | Ricoh Aficio 1018D Copier
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh Aficio 1018 photocopier
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
78 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
