Question about Linksys Wireless-G WRTP54G Router
Resetting a wireless-G access point
Dear Sir,
When you are inserting the clip in the reset hole do you unplug the power before you insert the clip or you can just insert while the system is still pluged to the power?
G S-Dery
    Brigadier General:
  • 6,966 Answers
It is not necessary to unplug, but it must be powered off. Basic steps then would be:
  1. Turn your DSL modem off.
  2. Locate, on the back of your Linksys router, the small button that reads Reset
  3. Press, and hold, the Reset button down for 30 seconds.
  4. Wait for your Power, WLAN and Internet light to turn on. (On the router)
  5. Turn your DSL modem back on.
  6. Open your web browser to see if you have an internet connection. If you still don't have an internet connection you may need to restart your computer.
Some tips:
  • When pressing the Reset button down make sure you don't release the button until you are sure if has been compressed for 30 seconds or more.
  • If you continue to have trouble with your internet the contact your local internet provider.
  • This will erase your configuration, so if you have previously opened ports for gaming, they will be blocked again. Try unplugging, then plugging the Linksys back in for the same effect without erasing the configuration.
  • Depending on what service provider you use, if your router's IP address has changed during the reset, it may take up to 24 hours for their servers to recognize this change and assign you a new IP address. During this time your connection will show as "limited or no connectivity."
  • On most Linksys routers your username/password combination becomes empty (no username) / with password "admin" (without the quotes).
  • The default settings for most routers is DHCP, NAT, or some other form of automatic IP addressing. Take this into consideration if you've changed your router's settings to assign static IP addresses.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 22, 2008
How to restore a new password wireless?
Most Wireless access points have a hidden button at the back in a hole where you can insert a bent paper clip. Holding the button in for up to ten seconds resets the wireless router to its defaults. The password is then set to the manufacturers default which you can search for online.
Mar 12, 2015 | Computers & Internet
NexAira Password Help
Try this:
add "admin" as the password.
If this does not work then try this:
Instructions
    • 1 Unplug all cables from the router except the power cable. Power on the router.
    • 2 Locate the reset button. This is typically a small hole marked "Reset."
    • 3 Insert the straightened end of a paper clip or the point of a ballpoint pen into the hole. Press and hold for about 10 seconds. Lights will blink, indicating that the unit is rebooting.
    • 4 Refer to your user's guide and follow instructions on setting up a new router.
Aug 01, 2012 | NexAira Business Class 3g/4g Broadband...
Ydi ap plus won't reload factory defaults
Try This:
Aug 01, 2012 | YDI Computers & Internet
I forgot my password how can i reset it and make a new one
The password would be blank/admin/smcadmin by default. Blank password implies that you need to click on login without giving any input.
But, if you have set a password on your own and not able to recollect it, try resetting the router.
To reset router do this.
You will have to use a paper clip or a similar pointed object to do the reset procedure.
Hard reset: Insert the paper clip to the reset button and hold it down for 15 seconds, while the paper clip is still in unplug the power cord that goes in to the router, now wait for 15 more seconds and then give the power supply back to the router, again wait for 15 more seconds and finally let the clip go. You will see the router's LEDs flashing. If this happens it means that we have successfully completed the reset.
Feb 06, 2011 | SMC Barricade g SMCWBR14T-G Wireless...
Wireless access point Pda 1360
To perform a reset, please follow the steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Note: Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults including IP address, username and password.
May 29, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
How do I reset password on my gateway 2 wire?
Straighten a Norwegian paper-clip,
and insert the end into the small hole in the back of the 2WIRE, to "reset" the unit to its "factory" settings, including the "default" ID/password.
Then, reconfigure your wireless network.
Apr 02, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Belkin n1 vision turns on starts loading then shuts off
Hi Friend,
This may the issue because of the below,
Cause 1: Try to insert the Power plug adapter in any other wall outlet
Cause 2: Check by Resetting the Router,(Insert a Pen or Paper Clip inside the Reset hole and hold the button until the lights are getting turn off,once its goes off without taking the hand from the reset unplug the power cable from the router and plug it again after 10 sec,Now take the pen or paper clip from the reset hole)
Cause 3: Even now you are not having any solution,then the router is gone bad,you may go for a replacement
If any other clarification,please feel free to contact us
Regards,
Ayyasam
Mar 31, 2010 | Belkin N1 Vision Router
Wireless device problem
For virtually any router, wireless access point, or modem, you will find a tiny round hole just big enough for an unbent paper clip to be inserted. The word reset may be next to that hole, but not always.
Pushing the unbent paperclip into that hole firmly for 10 to 30 seconds will reset the device to the original factory settings.
If you have the quick-start guide or manual for the device, you can use that to set it up. If not, visit the web page for the company and look for tech-support or downloads to find the manual for that particular device. You can also Google the actual device and part number information along with the words 'manual' or 'setup' and find the page that way.
Sep 05, 2017 | Intel PRO/Wireless 2011B LAN Enterprise...
Intel PRO/Wireless 2011 LAN Access Point (WEAP2011EU)
Usually there is a paper clip sized hole in the back of the WAP that you insert a pin or paper clip into for 10 seconds.
Jun 09, 2007 | Intel PRO/Wireless 2011 LAN Access Point
How do I RESET the router?
You will have to use a paper clip or a similar pointed object to do the reset procedure. Hard reset: Insert the paper clip to the reset button and hold it down for 15 seconds, while the paper clip is still in unplug the power cord that goes in to the router, now wait for 15 more seconds and then give the power supply back to the router, again wait for 15 more seconds and finally let the clip go. You will see the router's LEDs flashing. If this happens it means that we have successfully completed the reset. Soft reset: Login to the router, go to the Tools menu, click on configuration tools and select the option restore router to factory defaults to reset the router.
Feb 19, 2006 | SMC Barricade 7004
Linksys Wireless-G WRTP54G Router Logo
117 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
