Question about Snom 320 IP Phone
Snom 320 Freezes/Hangs
Good morning.
I have an snom 320 and have been using it for almost a year, this morning I received an error on the snom 320,it hangs/freezes, I switched the power off and turned it on again but to no avail it still hangs.
How do I reset the phone or get it past the hanging/freeze stage.
Thanks in advance.
5 Suggested Answers
SOURCE: my snom 300 is dialling letters instead of numbers how do I fix
Change the mode, as u change in ur mobile phone while typing the SMS.
Press the arrow key in upward direction and u willl see the change on the screen.
At the upper side of the screen u will see '123' .
Posted on Dec 02, 2008
ted1430
  • 339 Answers
SOURCE: i forgot the password and cannot access the web interface
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Posted on Jul 12, 2009
  • 4 Answers
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Posted on Oct 22, 2009
SOURCE: my snom 300 phone rebooted but displays NR
Go to vlan settings, then pick reset . The phone would restart itself and that should do the trick.
Posted on Jul 20, 2010
  • 10 Answers
SOURCE: HOW DO I UNLOCK MY
To lock or unlock a Snom 300 keypad you will use the * key. Hold this down until the lock icon appears and hold down again until lock icon is gone to unlock.
Posted on Jan 14, 2011
How to fix snom 300 because it cannot received calls
Is your phone connecting to a hosted PBX provider or is it connecting to a premise-based IP PBX? Incoming and outgoing calls are usually handled by two separate connections between your PBX and the service provider SIP trunk. Sounds like a registration problem with the SIP trunk. There is nothing you can do from the phone itself to fix this.
Nov 16, 2014 | Snom 300 IP Phone
Snom ONE SoHO IP address finding
The IP address cannot change if it is a static IP.Only dynamic IP address can be changed.You can check your static IP address in this site Ip-details.com .
Dec 29, 2012 | Snom One Soho Ip-pbx
I have a snom 320 dialling out takes long time for connection
I guess this is a SIP phone , try dialling the number then add # at the end, a SIP phone does not know when you have finished dialling unlike a landline so # complets the dialling for you
Jul 12, 2012 | Snom 320 IP Phone
HOW DO I UNLOCK MY SNOM 300 KEYPAD?
Jan 14, 2011 | Snom 300 IP Phone
My snom 300 phone displays NR help please
try resetting the vlan settings if that doesnt work ensure that the default gateway and dns settings are correct.
Dec 08, 2010 | Snom 300 IP Phone
Cannot update firmware Snom 300
It's not really asking for a TFTP update, it's just something that is always checked for in the boot sequence.
As for manually setting the networking configuration rather than using DHCP, see page 14 of the manual at
http://www.snom.com/uploads/docu/UM_snom3xx_V2.2_en.pdf
for instructions on how to bypass DHCP and manually configure your settings.
Dec 22, 2009 | Snom 300 IP Phone
The display on my Snom 320 doesn't work? The phone's lights also don't work, but the buttons and functions do work. Is the phone broken? This is a brand new phone, just out of the box.
Do you have the power brick hooked up to it? If so, try another one if possible as it could be the defective component.
If you're using POE to power it, make sure you have pluggd into a POE port for sure.
If you still have problems after this, then you need to return it for replacement unit.
Sep 11, 2009 | Snom 320 IP Phone
I forgot the password and cannot access the web interface of snom 300, version of firm ware is 7.3.23, I have tried to reset it but it again asks for password. I have tried user name as 'admin' and...
Jul 02, 2009 | Snom 300 IP Phone
Can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Jan 23, 2009 | Snom 300 IP Phone
How to unlock phone
Press and hold down the * button until lock is removed.
Mar 27, 2008 | Snom 320 IP Phone
Open Questions:
Cannot dial out on an SNOM320 SIP Phone I have forwarded the ip address of the phone through the router as a DMZ. I can call out using the software on my computer without any issues but not using the phone. Here is the log file information: System Information: Phone Type: snom320-SIP MAC-Address: 0004132C7E7D IP-Address: 192.168.1.101 Firmware-Version: snom320-SIP 8.7.3.19 Firmware-URL: http://provisioning.snom.com:80/download/fw/snom320-8.7.3.19-SIP-f.bin Production Information: Mac:0004132C7E7D;Version:Standard;Hardware:snom320 (H: R2A);Date:25/06/08;Copyright(C) snom technology AG Uptime: 0 days, 0 hours, 1 minutes LCS: 0 days, 0 hours, 0 minutes (0) Memfree: 1580 K CPU: 0.03 0.01 0.00 1/10 10 Bootloader-Version: 1.1.3-u Expansion Module: (0) SIP Identity Status: Identity 1 Status: 12262898960@voip.freephoneline.ca: OK Identity 2 Status: Identity 3 Status: Identity 4 Status: Identity 5 Status: Identity 6 Status: Identity 7 Status: Identity 8 Status: Identity 9 Status: Identity 10 Status: Identity 11 Status: Identity 12 Status: Ethernet Status: Net Port: Connection Type: 100 Mbit Full Duplex Status: connected PC Port: Connection Type: Status: not connected Call being received by Snom320: 9/2/2013 11:28:08 [NOTICE] PHN: RTP: set_destination adr=208.85.216.38:11468 Call being placed by Snom320: 9/2/2013 11:28:08 [NOTICE] PHN: RTP: set_destination adr=208.85.216.38:11468 9/2/2013 11:28:36 [NOTICE] PHN: TPL: Socket 31 idle/connect timeout 9/2/2013 11:29:01 [NOTICE] PHN: SDP: Skipped Codec G723 is not supported for 20 ms packets 9/2/2013 11:29:02 [WARN ] PHN: SIP: process_registrar_packet: 401 needs 128 bit nonce 9/2/2013 11:29:02 [NOTICE] PHN: SIP: process auth:Match challenge for user=12262898960, realm=voip.freephoneline.ca 9/2/2013 11:29:22 [NOTICE] PHN: TPL: Socket 32 idle/connect timeout 9/2/2013 11:29:34 [ERROR ] PHN: SIP: transaction_timeout udp: 1000018 (32000) 9/2/2013 11:29:34 [ERROR ] PHN: SIP: transport error: 1000018 -> udp:208.65.240.170:5060 9/2/2013 11:29:34 [NOTICE] PHN: SIP: Add dirty host: udp:208.65.240.170:5060 (0 sec) 9/2/2013 11:29:34 [NOTICE] PHN: SIP: final transport error: 1000018 -> udp:208.65.240.170:5060 9/2/2013 11:29:35 [ERROR ] PHN: SIP: transport error 1000018: generating fake 599 9/2/2013 11:29:37 [NOTICE] PHN: Fetching URL: snom://mb_exit 9/2/2013 11:30:35 [NOTICE] LID: testNetworkPolicyIsSet This has been frustrating me for a long time and I would appreciate any suggestions. Thanks.
Feb 09, 2013 | Snom 320 IP Phone
See all Snom 320 IP Phone Questions
Snom 320 IP Phone Logo
482 people viewed this question
Top Snom Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
