Question about Kenwood DDX-6019 Car DVD Player
Kenwood DDX6019 no screen function
Stero installed, bypassed the parking brake by grounding the wire out. All lights on unit come on and it will accept disks but not read them. The screen comes on but stays black what color is p-brake wire
  • Anonymous Nov 03, 2008
    It wont read the CD's
    Problem Solver:
  • 6 Answers
Brown
Posted on May 31, 2009
  • Anonymous Jun 01, 2009
    Sorry the parking brake wire is not brown is a light green
    New Friend:
I dnt have light green on my harness what other could it be thanks jay
Posted on Jul 07, 2010
Se non erro devi mettere a massa il filo verde
Posted on Oct 16, 2008
2 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: Kenwood DDX6019 no screen function
Grounding the wire out is probably not good enough unless this is an old model. The newer units require the parking brake lead from the head unit to be wired into a toggle switch. Take the lead wire it to one of the switch terminals, then wire the other terminal to the head unit ground wire. To make it work, simply toggle the switch twice-one up then down again. This imitates the parking brake being set. This is a dopey but effective illustration:
http://i132.photobucket.com/albums/q21/kthanid212/img057.jpg
This should get your screen working without the parking brake on.
Posted on May 08, 2008
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
How do I bypass the parking break to alow my kids to watch movies while im driving? (Kenwood DNX7100)
The parking brake wire (light green) from the kenwood unit needs to see ground. You could either ground the wire or use a toggle switch to ground the wire.
Sep 17, 2010 | Car Audio & Video
How can I watch dvd on my kenwood radio while I drive
you have to bypass the parking brake safety switch. Basically, right now it is wired to the ground on your parking brake. Figure out where it is by following the wire from the head unit. Disconnect it, and connect the parking brake wire to the ground for the radio itself.
May 14, 2010 | Pioneer AVIC-D3 Car DVD Player
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
How do u bypass the emergency brake sensor on the kenwood dnx8120?
exactly, just connect the parking wire to a ground source and your problem is solved. This hack also allows use of the nav. while the vehicle is moving.
Apr 04, 2009 | Kenwood DNX8120 DVD Navigation Receiver...
JUST INSTALLED A KENWOOD DDX6019 WITH GPS FUNCTION / WHEN DRIVING THE TUNER SWAPS ERRATICALLY BETWEEN CALL(BLUETOOTH) AND TUNER WHENEVER i PRESS MY BREAK. REASON? SOLUTION? THANKS.
You might have your brown (mute) wire shorting out (grounding itself) near your brake pedal. Locate the brown wire from the rear and make sure that it completely taped making sure that it does not touch anything metal.
Feb 22, 2009 | Kenwood DDX-6019 Car DVD Player
Kenwood kvt 729dvd
connect the green wire from head unit to ground perminetly
Feb 02, 2008 | Kenwood KVT-617DVD Car DVD Player
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Bypassing the parking brake safety
PUT THE GREEN WIRE TO THE GROUND IT ILL WORK I HAVE ONE
Apr 26, 2007 | Kenwood DDX-6019 Car DVD Player
I have the same unit with a simular problem I think it is a factory defect and I would take it back to where you bought it and excange it
Mar 09, 2007 | Kenwood DDX-6019 Car DVD Player
Kenwood DDX-6019 Car DVD Player Logo
579 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
