Question about Canon PowerShot A310 Digital Camera
Error 18 I see an error 18 what does it mean?
    Sergeant:
  • 255 Answers
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Posted on Aug 29, 2005
SOURCE:
What does 0406 error code on BEKO washing machine mean
Hi, Beko error code format is usually preceded by an E and goes from 1 to 18 or 19. E.g.: E1, E2...E18. Please post a picture of the error code display and your model number and one of the readers may be able to help you.
Oct 09, 2018 | Beko Washing Machines
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Riso- RZ220 codigo de error 18-531, el cilindro no se puede sacar .
The error code should start with a letter. Is it 'P'?
Error P18-531 means: Print drum lock is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Check te solenoid! Maybe it is defective or only stuck.
Mar 01, 2011 | Riso RZ220 Duplicator
Error Code 63 on Phillips Plasma - what does it mean?
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
What is error code 220602 on the wii
220602 means there is a problem with the internet settings.
when entering your setting use manual settings to set up. manually entering the DNS settings when the screen comes up.
(note: errror code 32002 means the same thing)
Jan 03, 2009 | Nintendo Wii Console
Error code 51330 mean
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US&action2.x=22&action2.y=18
Copy and paste the above link to get a solution to your error which deals with the network connection for the Wii
Nov 12, 2008 | Nintendo Wii Console
Error #18 Lens will not close and camera shuts off
Hey louboyens,
According to the manufacturer error code 18 is a lens error code. What that means is something is obstructing the movement of the lens. I would make sure that your hands or anything else is not preventing the lens from moving correctly when your powering the camera on, and make sure the camera is powered off and not powering on while in your camera bag. Try turning it off and back on and after this the camera still displays the error code you should probably have it looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 15, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Canon PowerShot A310 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
