Question about HP PSC 1410 All-In-One InkJet Printer
PSC 1410 HP printer
Paper feed is not normal. One by one feed is ok provided paper is carefully located. Can it be repaired?
  • 928 Answers
Must be the paper sensor. Try cleaning the printer near the paper feeder and see if any dust or dirt has accumulated. As for repair depending on the problem paper sensors sometimes cost as much as a new unit so it would be useless.
Posted on Aug 22, 2008
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Where is the paper loaded on a hp psc 1410 printer?
On the back of the printer.
There's a panel that opens partway to reveal the normal adjustable-width paper guides, and the paper is then gravity-fed in to the printer.
Jun 28, 2010 | HP PSC 1410v All-in-One Printer
My printer, HP injet 1410, could not pick up the paper. Can you tell me what the problem is.
I assume the printer is making noises and moving, TRYING to pick up the paper...
If so, there are 3 possible issues:
1) you have too liittle paper in the paper tray. Add more paper so that the tray is full to around 3/4, not less.
2) You may have too much paper on the tray. Remove some paper from the tray untill the tray is around 3/4 full, not more
3) The rubber rolls that pick up the paper may be dirty with paper dust or dirt. Put 2 drops of alcohol on q-tip and carefully clean them. Let dry 30 mins. before trying to use the printer.
Mar 26, 2010 | HP PSC 1410 All-In-One InkJet Printer
Problems with printing photos. Hp Psc 1410
check the configurations again, if the problem were still there, try with other cartridges.
Aug 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp psc printer paper feed is jammed with an piece of paper.
The small gear located in the paper feed assambly is break or fail, need replacement parts to repair it.
May 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1410 paper jam error
I had an HP printer do this, and the rollers were worn out. I had to replace the printer and it was not very old.
Nov 21, 2017 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Problem with hp psc 1410
My printer will scan and print , but it wont print from the computer, I need to activate it but I lost my disk.
Jan 17, 2008 | HP PSC 1410 All-In-One InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
130 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
