Question about Uniden Lands Phones
Uniden DigitalClarity 5.8GHz (DSS7855 2) Intermittent fault. Almost daily, doesn't ring for incoming call or rings and no connection. Having to disconnect power and phone for several minutes to "reset"
SOURCE: Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Posted on Apr 24, 2008
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Posted on Mar 03, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
ALIENAMERICA
  • 88 Answers
SOURCE: incoming ring volume
It has been my experience with these office phones, that you need to change the volume while somone is calling or while the phone is ringing. Try that, have someone buzz the phone, then while it is ringing, click the volume button up or down.
Posted on Sep 10, 2009
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
Uniden phone constantly ringing
Hello, it sounds to me like you have a dying battery which may cause the phone to ring constantly.
ryan44z
www.cobaltsys.net
Nov 09, 2009 | Uniden Cordless Phone
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Rings only 3 times then message
I did not see what model uniden phone you have. check here for a manual http://www.uniden.com/index/manuals_results.cfm?cat=1
Feb 15, 2008 | Uniden Cordless Phone
Uniden 5.8Ghz phone.
Jan 20, 2008 | Uniden Cordless Phone
Lands Phones Logo
283 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
