Question about Gateway MX6421 Notebook
Hay dose the laptop drive has the option to change the mode for cable select to master
  • mohamad8148 Aug 22, 2008
    i am having a problem with my hard drive. the laptop is not reading the hdd
  • mohamad8148 Aug 26, 2008
    haw what would the problem be if the motherboard doesnt read the hard drive
  • 79 Answers
Laptop drives are hard drives but as there is only one you cannot use CS/MSR. If there is a problem with your drive not reading this can only be 2 things - either the BIOS has been changed or the drive is dead. Reset the BIOS and let the machine boot. If the drive is not detected it is likely a dead drive - sorry.
Posted on Jan 25, 2009
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
On the bottom ther is two Zz what is it and what dose it do also how do i turn it off fn + f1 is not working
The zz mean that the computer is in sleep mode. Pressing the fn+F1 keys actually induces the sleep mode for your pc. To turn off sleep mode,follow these instructions.
1. Go to the task bar in the lower right corner of your screen.
2. Right -click on the battery icon and select Power Options.
3. This will bring up the Control Panel\Hardware and Sound\Power Options window.
4. On the left hand side of the window, select "Change when the Computer Sleeps"
5. This will bring up the Control Panel\Hardware and Sound\Power Options\Edit Plan Settings window with options for different settings on the battery and plugged in.
6. Click on the arrow for the drop down menu next to Put the Computer to Sleep>Select Never (last option) do this for both plugged in and battery mode if this is your choice.
7. Click on Save Changes.
Apr 26, 2011 | ASUS Computers & Internet
Similar Problem
If it is a SATA drive, check the manual of the motherboard for SATA options/configuration in BIOS.
If it is an IDE drive, I suspect a bad configuration.
Set the jumper in CS (cable select) mode. You may connect it to the primary (end) or to the secondary (middle) connector of the IDE cable. Be sure there is no other drive on the same cable. Turn on your computer and verify if there is any changes in BIOS.
If the drive is not seen in BIOS the cable or the unit may be damaged or incompatible with your computer.
If the drive is seen in BIOS turn the computer off.
Now, you may add any other drive (if any) on the remaining connector on the same cable as it follows :
- set the jumper as Master or Cable Select if you connect the drive to the primary connector (end), or
- set the jumper as Slave or Cable Select if you connect the drive to the secondary connector (middle).
Oct 07, 2009 | Acer (99.B0311.002) Internal 50x CD-ROM...
I need jumper settings. I'm converting it to an external hd.
You should be able to use it as Cable Select or "CS" address the label of your drive to establish which pins need to be jumped for this mode.
Certain manufactures are different, and require drives to be set to Master while on certain controllers, such as the one you are using for External.
These settings will not harm the drive, providing you follow the label, you may just have to use trial and error. Just make sure you stay within the "CS" "MA" "SL" or Cable Select, Master, and Slave options.
Hope this information helps.
Apr 25, 2009 | Maxtor Hard Drive
Hard drive problem
Although I covered most of the ways to speed up Windows boot time in another article, I encountered a unique roadblock recently that made me write this article.
During the last week I was asked by a customer to upgrade one of their office computers from Windows 98SE to Windows XP. Normally this is pretty standard, however because their current hard drive was only a 20GB with a gig or so remaining I wanted to upgrade their hard drive as well.
I proceeded to ghost the drive to a larger hard drive and then installed an upgrade version of Windows XP on top of Windows 98 to preserve all of their settings and programs.
Everything went flawlessly, until I was finished...
After I completed the Windows XP upgrade, I shut down the computer completely and restarted it. The computer took FOREVER to boot into Windows XP. It was literally 2 minutes before I saw the Windows XP logo screen and another 30 seconds more before the desktop appeared. This was definitely a problem.
After checking multiple settings in the BIOS, I compared the old and new hard drives. Everything seemed to be normal, except one. The old hard drive was setup to Cable Select and as my normal routine I had set the new hard drive as a Master drive. I changed the new hard drive to Cable Select, rebooted the computer, and the Windows logo screen came on seconds after the POST screen as before. Therefore, I have to add one more item to my list of ways to make Windows boot faster. Try changing the hard drive from Master to Cable Select, check the boot up speed and switch back to Master if you don't see a change.
Master/Slave Settings
Now for a refresher course on hard drive connections. When connecting more than one hard drive to a computer on the same IDE controller, you generally have to assign one as the primary (master) and one as the secondary (slave). You do this by changing the jumpers on the hard drive next to the power connector. Normally, the drive will have a diagram to let you know which jumper should be set for a master drive and which to set for a slave drive. You'll notice in the picture below the jumpers are circled on the end of the drive and the top of the drive shows the diagram to follow.
After changing the jumpers, connect the hard drive cable from the motherboard to the hard drives. Under normal circumstances, the end of the drive cable attaches to the Master hard drive, while the inside connector on the cable connects to the Slave drive.
What About Cable Select?
Cable Select (CS) settings were designed to make it easier to connect hard drives because you didn't need to bother with setting the Master/Slave jumpers. You just connect the drives and depending on where you connected them to the cable the computer would know which is Master and which is theory. Now comes the confusing part.
With cable select, you first needed a special 40 conductor IDE cable that would determine master/slave connections. This was different from the normal IDE cables at the time. Also, the Master connector on CS cables was the inside connector not the end connector. This made for a very confusing switch from everyday master/slave configurations.
80 conductor Ultra DMA cables WILL determine the Master/Slave settings through Cable Select however. So as technology advances, Cable Select as a concept may still catch on. With the newer Ultra DMA cables, you can set both drives to Cable Select (CS), connect them and they will work. Another change with the 80 conductor cables, the Master connector is on the end of the cable where it should be. In situations where you are using a newer Ultra DMA drive and cable, you can use Cable Select or standard Master/Slave jumper settings and the drive will boot properly.
In my scenario to start this article, the change from Master/Slave to Cable Select for this particular computer reduced the Windows boot time by more than 2 minutes.
For more information on Master/Slave settings versus Cable Select visit the following pages:
Mike's Hardware: How to Connect IDE Hard Drives
Configuration using Cable Select
UnixWiz.Net: Using IDE Cable Select
Oct 18, 2008 | Computers & Internet
Jumper Settings
If you leave it at cable select the cable will set the drive to either master or slave depending on where it is on the cable, the first or second connector. Just make sure any other drive hooked up is set to cable select.
Your best option is to actually set each drive to master and slave. Each drive should show you where to put the jumper. Make sure you only have one master and slave though.
Which jumper to use? The one thats already on the HD...?
Check out this page for more information on Cable Select:
Aug 22, 2008 | Maxtor Hard Drive
Hard Drive
The IDE cable or the power cable are not connected. Also may be it is acting up due to master/slave problems. Pull out the jumper and put it into CS mode. CS means cable select. Try it and let me know..
Aug 22, 2008 | Gateway MX6421 Notebook
I installed an additional hard drive in my laptop. The computer will no longer boot up. I've read the the BIOS needs to be changed by I don't know how.
Please tell me which Motherboard your system has???
If you have added an additional drive, check whether you have set the jumpers right for master/slave/cable select configuration.
If you bios setup to boot up from first HDD, then the bootable HDD shall be in master mode. Configure bootable HDD as master & additional one as slave.
If still no luck, Put this additional HDD on other IDE slot.
Tell me if this works...
Jun 21, 2008 | Computers & Internet
Using master, slave or cable select jumper
89c8602.gif SETTINGS:
A - Cable Select Mode
B - Slave Drive Mode
C - Mater Drive Mode
Mar 01, 2008 | Lite On (LTN486S) Internal 48x CD-ROM...
Cannot get harddisk
check both hard drives for jumper position. A typical layout will be: master jumper in master position (see label on back or top of drive), then slave drive jumper in slave position. These jumpers are small and sometimes require the use of needle-nose pliers. Also, the data cable issue: A typical dual drive cable looks like one connector that is physically at the end of a cable yet farther apart than the other two. This gets connected to the motherboard. At the other end of this cable, you will see a connector (for master drive) and nearby, another connector (for slave drive). If your drives support the CAS mode (cable select), then it is irrelevant which connector these drives belong to (assuming you use the 2 closer connectors). If not, it is is imperative that the drive jumpers be properly positioned as described above. Finally, if the above steps were followed and still same problem, then change the BIOS setting from AUTO to forced type. Some BIOS's require the CAS mode to be present on both drives. This can get complicated, but simply write down the settings from each drive (ex: cylinders, sectors, heads...) and then type in these settings at the BIOS screen.
Jul 25, 2007 | Asrock P4I45GV R5 Motherboard
Gateway MX6421 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
