Question about Andis 01690 Hair Trimmer
Andis adjustment can get my master andis adjust so it can cut very sharply. I have a new blade but can seem adjust them right
  • 61 Answers
Blades has to be set precisely,only then will you get a crisp cut.
Posted on Jan 26, 2009
  • 62 Answers
For directions on how to install a new set of blades please visit the Andis website at www.andis.com. Click USA, Service, Use and Care, and then the model ML. If this still does not work please call the Andis customer service department at 1-800-558-9441 for further instructions.
Thank you for choosing Andis.
Posted on Nov 13, 2008
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
My Andis Masters
tention is probably to tight, or blade needs to be realigned
Mar 11, 2009 | Andis Outliner II Hair Trimmer
My GTO model Andis clippers blade is not properly aligning..how do I adjust it?
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Andis masters are chewing my guards
Stop using speedo guards and get yourself an oster 76 and all the blades.
Aug 16, 2007 | Andis 01690 Hair Trimmer
Andis 01690 Hair Trimmer Logo
1,080 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
