Question about Dishwashers
We have an indesit D64 dishwasher it won't cycle through the programme without manually turning each stage throught the dail
localwonder
  • 6784 Answers
SOURCE: My indesit dishwasher won't heat the water. I
HI. this is actually a control issue. your element is ok. replace the control board or timer module asap.
Posted on Aug 27, 2009
reddyanantha
  • 205 Answers
SOURCE: CDA dishwasher (model number CW496) , stops
hello sir/mam if the dish washer stops at rinse cycle, please check the programmer and the drain motor connections if the connections are good and you find the normal power supply at the time if drain then please change the drain pump.
Posted on Sep 21, 2009
Testimonial: "thankyou "
BIKER T
  • 909 Answers
SOURCE: I have an Indesit Dishwasher model the programmer sticks
One of the main reasons for the timer sticking, is the heating element is not comming on. Check if it is faulty or if the over temp. th/stat has activated.(Basically,check if water does heat at any time.. if not, there is the problem).
SOURCE: Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Posted on Oct 06, 2009
mc1bean
  • 3053 Answers
SOURCE: I have a built-in indesit
Hello, the
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Brand new Indesit IDS105 Dishwasher will only complete pre wash cycle, on any setting.
Purchased a second hand Indesit slimline IDS105, to find it would only complete the first wash cycle, at the end of this cycle the LED Would just flash, with the waste pump coming on every 2 mins to empty it. Even after 4 hours it still didn't complete a full cycle.
I looked through the manual only to find that the error code was not explained. I phoned Indesit, after talking to 12 different people, the only thing the useless company wanted to know was whether i had warranty or whether i wanted extended warranty, then after establishing i didn't, they just biffed me on to the next, when i actually got through to a loosely knowledgable person they said they would send out an engineer for you as we are not allowed to tell you what the error code means, I just put the phone down.
So... to the solution, after dismantling the dishwasher i tested every single component, with a multimeter. Through elimination and research i had a hunch it maybe to do with the heating element or NTC Temp sensor. Tested the NTC, perfect. Tested the resistance of the heater this read 0.34ohm near enough should be around 0.29. So i took the mainboard out and tested the relay and this is where my trouble and solution arose. To test the relay i got a 12v battery and the datasheet for the relay, tested the contacts, to here a nice click....Then pop!!! NOOOO i blew the IC that controlled the Relay (ULN2003A Darlington transistor array). I ordered one of ebay (but RS,Farnell sell them for a cheaper price) Unsoldered the blown IC, soldered the new one on.
Put the Dishwasher back together, crossed my fingers, turned it on, and selected programme 2 (Normal wash) and pressed start. 1 hour and 50mins of intense tension later it had completed the whole cycle!!!!!!!! Ive never been so happy!!!
Cheers
Up yours Indesit!
Sam
Jan 16, 2013 | Indesit Dishwashers
INDESIT IDS105 WASH LIGHT FLASHING
So... to the solution, after dismantling the dishwasher i tested every single component, with a multimeter. Through elimination and research i had a hunch it maybe to do with the heating element or NTC Temp sensor. Tested the NTC, perfect. Tested the resistance of the heater this read 0.34ohms near enough should be around 0.29. So i took the mainboard out and tested the relay and this is where my trouble and solution arose. To test the relay i got a 12v battery and the datasheet for the relay, tested the contacts, to here a nice click....Then pop!!! NOOOO i blew the IC that controlled the Relay (ULN2003A Darlington transistor array). I ordered one of ebay (but RS,Farnell sell them for a cheaper price) Unsoldered the blown IC, soldered the new one on.
Cheers
Up yours Indesit!
Sam
Jul 09, 2012 | Indesit Dishwashers
Hi, our Indesit IDL500 dishwasher has stopped working. The fault light 2 is flashing. The manual doesn't mention what fault this indicates. Any ideas. Cheers, Neil
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
Sep 26, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit wd10[uk],when placed into wash cycle 4 ,washes,then spins and after spin returns to wash 4 cycle,ad infinitum.
strip down programmer/timer motor,found contact fingers not making circuit with printed circuit card,adjusted fingers,rebuilt timer,tested,ok.$100 please mam!
Feb 27, 2008 | Indesit Dishwashers
Indesit IDL40, 2nd & 3rd light flashing
It can also be that the pressure is too week. If you look a tthe manual it mentions this exact symptom. I know because i ve a similar issue. cheers
Dec 13, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
