Question about Compaq Deskpro EN PC Desktop
First CreateDevice failed
When i start to play the game it says 'Mode could not have been initialized. can u tell why this message is coming.
    Problem Solver:
  • 8 Answers
Which game ?
Posted on Aug 22, 2008
Fmod failed to initiliase
You may not have enough memory to finish the game or start. Harddrive space may be the factor also. the game on the cover should tell you how much memory and hardrive it will take. And processor speed you need to play your game.
Apr 30, 2014 | Sony F.e.a.r. 3 Playstation 3, 2011
"Failed to attach personality"
When I start Chessmaster, and click on Play-Trining Mode, it says "failed to attach personalities", and I can't play chess
Jul 29, 2009 | Ubi Soft Chessmaster 10th Edition
Upon startup of game get this error message- "unable to initialize video mode: could not set screen mode."
try download n install latest driver..
Here is something you can try for now:
Many games provide an option to be started in "window"-mode instead of fullscreen.
Open a terminal, cd to the directory where the game is installed and start it from there, but append "--help" behind the command name (or "-h" if that didn't work)! Keep an eye open for an option that looks as if it starts the game in window-mode.
Jul 24, 2009 | Atari Desperados 2: Cooper's Revenge for...
Medieval Lords Installation error!
1st extract the contents of d virtual disc using POWERISO den run setup it wil install perfectly (directly instalin game by mounting image causes it 2 restart)
Jun 28, 2009 | Monte Cristo Medieval Lords for Windows
Initialization failed
Likely due to graphics card, update the drivers for you video card
see microsoft's article related to this issue http://support.microsoft.com/kb/811553
Feb 03, 2009 | Microsoft Age of Mythology for Windows
You need to uninstall and Reinstall the particular game.. or try system restore for quick resolution
Feb 03, 2009 | Microsoft Windows 98 for PC
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
Compaq Deskpro EN PC Desktop Logo
124 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
