Blomberg 1301abb washing machine
Washing machine now doesn't work no power this is why i fitted a new interlocking door catch to my blomberg 1301abb washing machine after messing with the old catch when i shut the door and turned it back on there was a electrical flash, which blue the cable & its holder out of the small board which it sits in.i then put the new  catch in but it wont work no power have i blown the main pcb board or is it the on off switch
2 Suggested Answers
  • 521 Answers
SOURCE: blomberg washing machine 1301abb I
its the main board problem.some thing has gone short.get the board checked with proper technician.it will not cost you much.thanks.
Posted on Aug 21, 2008
Pyrhyc
  • 2028 Answers
There should be an in line fuse to keep from blowing the main board. Check this fuse, and also check the main board for scarring, electrical burns, or any other noticeable damage. If there is no noticeable damage, then I believe that you're going to have to replace the blown circuit in order to see if the main board was affected.
HOTPOINT 9526 DOOR STAY LOCKED AFTER FINISHED THE CYCLE
The first thing to check is - does the washing machine still have water inside? If there is obviously still water inside the machine then this is possibly the cause of the door not opening. Drain the machine.
Can't see any water inside
If you can't see any water inside then it may be caused by various faults listed below. Here's a list of the most common causes of a jammed door -
  1. On some machines if the pressure switch doesn't reset to empty it keeps the door lock energized. If this is the case though, unplugging it should allow the door lock to cool down and open after a few minutes.
  2. The water hasn't pumped out properly (or a blockage in the pressure system is holding the pressure switch on) - but only if the washing machine has a pneumatic (air operated) door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
  3. The water has pumped out properly, but the pressure switch hasn't reset due to a faulty pressure switch or blockage in the pressure system - or the water hasn't pumped out properly and the pressure switch hasn't reset because of the water inside. A faulty pressure switch, or blockage of debris inside the pressure chamber bottle could also be trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days).
  4. The door interlock has just jammed
  5. The door catch, handle, or some part of the door catch mechanism is broken and not opening the door
  6. ****** (a device that detects the motion of the drive belt fitted to many older Hotpoint washing machines which "pecks" at the belt when the door handle or button is operated) is broken or has fallen off
Opening a jammed door Do not take the lid off and reach inside the washing machine to try and release the door if the washing machine is still plugged in as you will be electrocuted.
The most common cause of a jammed door is likely to be a faulty door interlock. Sometimes you can release the door from the inside by manipulating the door interlock or forcing the door catch out from it. But they sometimes just have to be broken away from the machine. If you need to do this make sure you -
  1. Unplug it
  2. Break the interlock off from inside the machine, don't force the door or you will just break more parts
Jul 03, 2016 | Hotpoint Washing Machines
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
Door of Washing machine doesnot opened
the door interlock has failed
other then try to leave it off and struggle with the door
you need sometimes to release it from behind
not easy sometime with some machines
the replace the door lock interlock catch
it will work fine then
Sep 19, 2014 | Siemens Washing Machines
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
Door won't open on wf000
Never reach inside the washing machine with it connected to the mains. The door interlock is always live!
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoint’s - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunged can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank You for contacting Fixya.com
Aug 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
