Question about Acer AL1714 17" LCD Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Hi there.Before I subscribe my problem, sorry for my bad english, but I'll give my best.
I have an Acer AL 1714 for about 2 years now. Last days something strange happened. I just switched on my powerbar and my computer started already. But the screen of my LCD didn't. It still was black and the LED light blinked fast in an orange colour.. the big thing, between the cable from the computer, and the cable to the monitor, i think it is called transistor? its' LED light is blinking too in green. When I take off the cable from the monitor, the transistor stops blinking and it lights without a break. But when i connect the cable again to the monitor, it starts blinking again.. cant help myself :(
Thanks and I'm looking forward to reading some answers maybe..
  • Anonymous Apr 23, 2009
    I have the same problem as Memoreeze, I have been google searching but nothing so far.
Well, suddenly it worked again. But I waited the whole day >.>
Posted on Aug 22, 2008
You need a new power adapter, most likely.
Posted on Dec 23, 2008
SOURCE:
Acer AL1716 monitor goes black after a few minutes
if u have an extra gpu try it, becuase i hade the same problem and it was not the monitrs fault
Jan 12, 2018 | Acer Computers & Internet
ACER AL 1717 monitor.The on/off button is flashing green and orange, but the monitor is not turning on. I have checked all the connections.It blinks even if the connection from CPU is not given to it.
It sounds like you have a bad capacitor on your power circuit board located inside the monitor.If you take the cover off the monitor,you will see a circuit board where the power cord plugs in.On the board,look for 1 or 2 capacitors that are swollen or opening at their tops.They will usually be black in color with silver on top and round in shape.If you see any bad ones and have a solder iron and solder removal hardware,you can easily replace the capacitor(s) yourself,which you will find replacements at Radio shack or your nearest electronics repair shop.......good luck :)
Jul 05, 2015 | Acer Computers & Internet
Trying to connect a laptop acer aspire 5542g to an acre monitor al 1714, is this possible? As the monitor is showing just a blank screen with the green light steady. Was working 30 minutes ago on my mates...
Good Day,
This is possible there is supposed to be a switch on your laptop keyboard to make this easy
To activate hot keys, press and hold the lt Fn gt key before pressing the other key in the hotkey combination
you should see it in either blue or orange after pressing the FN key and that key together you will see the monitor switch
Feb 26, 2011 | Acer Computers & Internet
When I plug in the Acer monitor, it does not turn on. The LED light (that indicate whether the monitor is on (green) of off(orange)) just blinks. There is also a very faint 'clicking' sound.
in most cases the fault is not the monitor its the computer in some cases its due to dirty ram slots (clean them reinsert ram) in the worst case its your cpu
check your computer with another monitor then confirm its the pc have it looked at
Jan 02, 2011 | Acer AL1717 17" LCD Monitor
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 26, 2010 | Acer AL1914 19" LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Oct 13, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Acer One 1542 series.Power on but not boot.
since you reseated the memory, the last two things I would do is remove the hard drive and dvd drive.
If you remove those and you can't get video then the motherboard is bad.
Aug 03, 2009 | Acer Aspire One PC Notebook
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Oct 12, 2008 | Acer AL1714CB (Black) 17" LCD Monitor
Open Questions:
SBCglobal MAil HeLpliNe +*/{1-855*536*5666}#[email protected] NuMbER CUSTOMER HELP This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
See all Acer AL1714 17" LCD Monitor Questions
Acer AL1714 17" LCD Monitor Logo
2,233 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
