Question about D-Link DFM 562IS (DFM-562IS) Modem
No able to connect internet in dial-up
Error showing that is no dial tone
  • maskun_gante Nov 12, 2008
    Tlng Saya, Saya mau Upgread driver modem PCI CARD D-LINK....
  • 871 Answers
Sarang
be sure to connect the correct wires to its respective slot on the back of the modem, if theres only 1 slot, try to change the rj11 wire with another to test if there is dial tone.
Posted on Jan 04, 2009
How can I fix my majicjack plus to work with anew service provider?
tab_l.gif Answer tab_r.gif If you hear error 1 while trying to place a call with your magicJack, it means that you are not connected to the Internet.
You need to check your new internet connection first.
Then sign into
You must check your new internet connection gets to magicjack.com
sign into VoIP Phone Service Internet Home Phone Service Providers magicJack
Jul 12, 2014 | magicjack.com
No dial tone error when using my lg220c as a modem to connect 2 the internet
If you're talking about using a cell phone device as the modem or router so your computer can connect to the internet, just drop into your cellphone provider's store and let them show you.
May 29, 2012 | Computers & Internet
Cannot connect to isp using modem (dialup) get error code 680. using vista home premium.
error code 680 means there is no dial tone.
manually attach a phone to the phone jack you are connecting to and check if there is a dial tone. if there is no dial tone on that jack try a diff phone jack. if still fails call your telco.
if there is dial tone to other jacks it means the previous jack is faulty or damage.
Oct 17, 2009 | Computers & Internet
Was able to get connected to the internet twice to day when i came back in to get on the computer it couldnt connect to the internet said no dial tone. this is a new dell computer with an external modem...
Generally this is an indication of a modem failure. If there have been any storms in your area, then the modem may have been zapped. The dial tone curcuit is normally the first casualty when a modem gets hit with more power than normal.
Provided that your telephone is functional on that line (Unplug modem, and connect a handset if this is a modem only line and see if the handset gets a dial tone, this is a good check to make sure the line is functional)
Apr 17, 2009 | Dell Inspiron 530 Desktop Computer
When I try to connect to internet with dial up no dial tone
Here is a link to tell you if your modem is working or not.
http://www.56k.com/inits/a2z.shtml
Not sure what modem you have in your system but this is a link for all the modems.
I hope this helps. Pleasre rate.
Feb 18, 2009 | IBM ThinkPad R31 2656 Notebook
No dial tone on xp
U need to double confirm the phone line whether got dial tone or not. What u can do is to plug the phone line to a single line phone. If dial tone is available, u can able to make call.
Feb 13, 2009 | Dell Inspiron 530 Desktop Computer
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
There is no dial tone" in LG Internet Cube
i have tried the same thing and the dial tone has failed but i think you might have to have credit on your phone to do it but i'm unsure to cause mine won't work
Jan 04, 2008 | LG KG800 Cellular Phone
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
D-Link DFM 562IS (DFM-562IS) Modem Logo
112 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
