Question about ASUS A8V-VM Motherboard
Sata HD not seen by OS
During install I cannot get XP to see my sata hd. XP prompts me to hit F3 to reboot. I am at a loss here. help me please
  • 2 more comments
  • brysounds Aug 22, 2008
    Service was wonderful and stright to the point.
  • Original Flo Sep 08, 2008
    i try to install win xp 64 bit (but the problem persists even if i try the xp 32 bit version), but xp fails to recognize my sata hard disk. i do not know where to find raid controller drivers to incorporate them with nLite in a .iso image. can someone help me please?
  • jan_gundorf Oct 02, 2008
    Exactly the same problem here. What was the solution for this please?
  • sk singh Nov 18, 2008
    i cannot see my seagate Sata HD on my xp sp2 operating system.
    Please help.
  • 781 Answers
You need to insert "DriiverPacks" into a Windows CD copied to hard drive using "Nlite"
http://driverpacks.net/DriverPacks/
go to the above site for them
you need
"Driverpack MassStorage"
I did it just follow instructions
Posted on Nov 24, 2008
Sata Hard drive errors and Raid errors
See this answer
Reboot your system and hit F2 as soon as you see the Dell startup screen (the options are F2 for setup, F12 for boot sequence).
In the System Setup screen, do these steps.
Select Drives:
Make sure your Diskette Drive (3.5 floppy) is set properly (Usually set to Internal)
Make sure that "Drive 0: SATA-0" drive is set to "ON"
Go to "SATA Operation":
Your system proabaly came set to "RAID Autodetect / AHCI" - THIS SETTING CAUSES YOUR SYSTEM TO GO INTO AN IDE LOOP AND DOESN'T ALLOW IT TO FIND YOUR FACTORY INSTALLED SATA DRIVE.
CHANGE THE SATA OPERATION SETTING TO "COMBINATION"
Reboot - make sure that the boot sequence is set to CD rom before HD and make sure that the reinstall CD is in the drive. Setup will load, hit enter to reinstall XP. Your HD should now be detected and you should see the licensing agreement.
If you have your files backed up I reccommend deleting the partition and reformatting prior to installing XP, it will give you that option after the license agreement.
Once you have successfully reinstalled the OS, Dell reccommends that you change the SATA Operation setting back to RAID AUTODETECT / AHCI (or back to whatever your factory setting was) to avoid any problems with other IDE devices installed on your system.
Source
Restore Complete but Stuck on DRMK
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
I have HP Comaq Presario SR1617CL Desktop PC, part number ED870AA with a Samsung SpinPoint P80 SP1604N - hard drive - 160 GB - ATA-133, I would like to upgrade to a 500GB hard drive. I have a ASUS A8AE-LE...
XP cannot be installed natively on an SATA disk without the appropriate driver which must be loaded during the install - an extremely complicated maneuver. The best way to deal with that is to just add the new SATA hard disk: install XP on the PATA and use the new SATA for your files as a separate partition. The adapter cable can be bought for about $5 from the same shop as the hdd.
All the other modifications are just fine - just remember , the RAM will not be fully recognized and used because of the limitations of the 32bit XP.
Mar 11, 2011 | HP Compaq Presario SR1617CL PC Desktop
Cannot seem to get system to recognize SATA HD when installing OS.
The xp disc you have might not recognize the SATA hardware on your motherboard.
There are two ways that you can use to solve this problem
1.Slipstream the drivers of the motherboard into your xp disc
2. Use a external floppy drive to load the drivers by hitting F6 at the driver loadin page while you install the os
Dec 08, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
I cant format my cq40-126AU using xp cd with sata driver inside(n-Lite).i have 4 partition that in use that mean i use all space.i think it cause of 9MB require for xp?it is?? can anyone help me plez......
You may need to go into BIOS and set the SATA HD advanced properties to use legacy OS (XP is considered legacy by many SATA drivers (in BIOS). The XP CD will tell you there is no HD installed.
JC Hunter
Nov 11, 2009 | HP Compaq Presario CQ50-110US Laptop
Hd may be corrupted
Yes, definitely you can buy replace with any 2.5" laptop hard disk make sure that you buy HD with correct interface, if you old HD is IDE then buy IDE hard disk , elsei if SATA buiy SATA harddisk
RATE THIS SOLUTION!
RNJ VINOD KUMAR
Sep 13, 2009 | Dell Latitude D600 Notebook
Blue screen comes
dear sir
for hp laptop they told that this laptopr only support windows vista but if u need to install windows xp u hav to make a sata or scsi drvier disk or cd for making cd u have to download a software call "Nlite" it's a softwaere to make a bootable cd with sata driver or u need to install from floppy u have to perchase or rented usb floppy drvier it's help u....:)
thanks
please vote
jo_chinmay
Jan 05, 2009 | Compaq Presario Notebook
Recognize sata hd
No drivers are needed - it should have been seen right away. Check the BIOS to see the drive is seen in the drives tables, and if there, XP needs to have the drive setup using FDISK. The drive will not show under windows until a drive table is on it.
Sep 05, 2008 | Intel Motherboard
Replacement HD
Upgrade your bios
Nov 13, 2007 | ASUS K8V-MX Motherboard
ASUS A8V-VM Motherboard Logo
157 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
