Question about Imperial Kitchen Appliances - Others
Imperial deep fryer model: IFS-40
I have a problem on 3 unit of imperial deep fryer model IFS 40. The problem come from the flame from the burner is red flame( not the blue flame). And I check the size of nozzle of the burner is 5.1. I check the manual i see that it is wrong size to use with IFS-40. Could you advice and solution?
  • Anonymous Mar 13, 2014
    Fryer 4 Burner New thermalpile and gas valve clean. keeps booming on start up of main burner, orfices clean, pilot asembly good 1/2" infront of burners. Need gas pressure for manin header, pilot seems wide enough. Seems to fill burner area before ignition does shut of by temp and relights and booms at times above exhaust in flames. Think pilot is to far from burner Hood seems to pull pilot flame to forward of combustion tubs,I have manometer to check pressure on manifold. any sugesstions Helpful ?
  • Anonymous Mar 15, 2014
    I can turn on pilot but When i go to turn gas valve on to the burner the blue flame on pilot gets smaller causing the flame of pilot to not heat the thermocouple keeps on switching off is there a low supply pressure
  • 640 Answers
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Posted on Sep 04, 2008
Why does my fryer have flames shooting out of the vent
no doubt grease has been spilled on it sometime and it's burning it off the elements .
Sep 15, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Jul 23, 2010 | Imperial IFS40 Deep Fryer
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
Brunners will not light on my imperial IFS-40
WTF your pilot light might be out RUN LIKE HELL- air the place out then go back and re-light it.
Aug 25, 2009 | Imperial IFS40 Deep Fryer
Ifs 40 deep fryer
I have a used fryer, imperial, looks like the ifs 40 but can not find the model number on it. Do you have any idea how I can find the model number?
May 13, 2009 | Imperial IFS40 Deep Fryer
Fryer coming on without turning thermostat on
Imperial Model: IFS-40.
The thermostat is either very far out of calibration or has failed, either case it should be relplaced. The Imperial Part # for the thermostat is 1175.
May 04, 2009 | Imperial IFS40 Deep Fryer
My imperial IFS-40 is burning the door
Is this fryer propane?It sounds like the baffles in the tank are clogged.If you remove a burner shine a light in the baffle,if you see alot of soot use a shop vac and clean it out.Let me know.
Apr 23, 2009 | Imperial IFS40 Deep Fryer
Kitchen Appliances - Others Logo
400 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
