Port opener i cant seem to open my ports for utorrent for downloads. how can i pick a specific port for utorrent which happens to be open
  • 928 Answers
Go to options>preferences>connection
You can set the port there and also Upnp mapping so that if your router is upnp ready it will be automatic
Posted on Aug 22, 2008
Need find out how portforward can you tell me how udp and tcp ports open
Here is the solution to help you out to do the port forwarding as you wished sir..
2wire-gateway-1921681254-300x234.png Once you have accessed your default gateway screen for your router, you will then want to click on the firewall tab at the top of the screen. After the firewall summary screen opens, you will then click on the firewall settings tabs to begin setting up an open port on your 2wire dsl router.
2wire-firewall-300x234.png Once the firewall setting screen opens you can then add an open port to your specific pc. Under step 2 you will see a list of predefined applications that have already been created for certain video games, servers and telephony (VoIP) services. Since in my example we are opening a port for Utorrent, we are going to manually configure port forwarding for one of my pc's. To be opening a port for Utorrent, click on "add new user-defined application" you can find the link just below the list on the left side of the screen.
2wire-edit-firewall-settings-300x234.png Once you click on add new user-defined application, you should have a window that resembles the one below. Within this window you should now be able to enter a name for the application that you are opening a port for. Underneath the application name, you know have the choice of either tcp or udp, and then you would enter a port number or a port range that you want to open up.
2wire-add-user-definition-300x234.png For security reasons, you should only open one port, unless the application specifies otherwise. The more ports that you have open on you router, the more doorways you open for hackers and viruses to enter your home network. Since we are opening a port for Utorrent, you are going to want to click on the tcp box and then enter the port number that Utorrent gives you, in my example I am opening up port number 51225. After you have entered you port number, click the add definition button. Once you have added the definition, you are going to then click on the back button.
2wire-utorrent-open-tcp-port-300x234.png After you have clicked the back button, you should now be at the edit firewall settings screen. All you have to do now is select your computer from the list that is listed After you have selected the computer that Utorrent will be hosted on, all you have to do is find the recently created user defined definition from the list under number 2. After you have located the Utorrent port forwarding application simply click on the add button, which should assign the Utorrent port forwarding application to your computer. After you have completed the above steps, you should be all set; now your Utorrent program should download and upload at a faster speed.
I have used Uttorent as an Example for you to have an idea how to do the work.. if you still have any problems or question just send a message i will get to you as soon as possible..
If you like the answer and it helped you please like the answer, it will be a great help.. Thanks
Jun 01, 2011 | 2wire (2701HG-B) Wireless Router
Iv got a BT home hub 2 cant get conections for utorrent even though opened firewalls
There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though: http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
But if one knows the ports it is easy to block torrent.
If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
Jan 09, 2010 | Cnet CWR-854 Router
I need to open a port to use utorrent
first u download a software called ultra surf from anywhere on the net...then this software will search for most suitable port and it will open it for u...
OR
simply u can change the port no. between ' 6880-6889 ' in the preference option in utorrent....I think this will solve ur prob...KSHITIJ
Jun 17, 2009 | D-Link GamerLounge DGL-4300 Router...
Problem opening port for utorrent with DGL 4300 router
You must set static IP on your computer where the utorrent is installed. Make sure no firewalls are enabled on your computer like windows firewall or any other firewall like norton, mcaffe, zone alarm and the likes. You should forward the port on separate protocol. Go to portforward.com for more information on how to forward port for utorrent
Jun 14, 2009 | D-Link GamerLounge DGL-4300 Router...
Allocating a port to a download site
You can genarat or use any port you like via utorrent settings test the port is open at utorrents
Jan 24, 2009 | Computers & Internet
Router problem
Hello!
Here is a guide on how to setting up port forward on DSL 500T for uTorrent:
http://www.portforward.com/english/routers/port_forwarding/Dlink/DSL-500T/Utorrent.htm
If you can't reach the router as described in the link above, than you need to contact whoever provided you with this router. If the router was provided by your ISP (internet service provider) than contact them directly asking how to access your router.
Hope this helps!
Sep 23, 2008 | Computers & Internet
Utorrent port.
you need to manually add it in the port forward section of your router interface. typically a range of 10 - 20 ports. make sure it matches the ports listed in the utorrent options page.
Jun 27, 2008 | Computers & Internet
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Computers & Internet Logo
1,281 people viewed this question
David Payne
David Payne
