Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
Ryobi Chainsaw - PCN 4545
Hello there. My chainsaw bar and chain lubrication is not working. There does not appear to be any blockages???? The saw is 12mths old and has done about 10hrs use. Any thoughts????
Cheers
Ollie
  • renren1 Feb 10, 2009
    I didn't notice until my chain and bar were cooked... it's Ryobi model RY 10532...
  • Anonymous Apr 24, 2009
    No oil reaching chain. Have the saw half apart now, but still have no idea how to get down to the oil pump/gear area.
    President:
  • 2,220 Answers
Ryobi boasts a two year warranty. Have you contacted anyone about a warrantied repair?
An IPL (expanded parts list) for your saw with any oil system detail can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Posted on Oct 08, 2009
Oil not going on to chain
  • 211 Answers
Hi ollie69
check the oil filtetr,the oil hose,the worm gear and the oiler.
regards
Posted on Dec 02, 2008
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
PCN 4545 Chainsaw I unfortunately used unleaded petrol instead of 2 stroke, now can not get saw to start, is it game over for carberette?
Hi, it won't affect the carby which I'm afraid is the only good news. It will need a new piston and probably a cylinder. Depending on the price of these parts to suit your model it may not be worth repairing. Sorry Phil.
Jun 20, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
My Ryobi chainsaw PCN 4545 overheated
Sawdust/dirt build-up helps cause this situation. Usually, the band is deformed so that it drags. The melted case parts may or may not need replacement, but will likely need trimming. The band usually does as it is difficult to remove the small bends in it. After repair, make sure the chain turns freely by hand. Set and reset the brake several times to make sure it works correctly. The clutch outer drum rarely deforms when this happens. Hope this helps!
Jun 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Hi, I have a Ryobi PCN 4545 petrol Chainsaw that i have owned for about 4 years with little use. I went on a Chainsaw users course over the weekend and took the saw on the instructors recommendation....
http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/PCN-4545-_E
You probably don't want to hear this, but there have been many many problems with this unit. It is now, discontinued, Personally, I would get another one, any other one. To have any chance of any type of repair, you must get a service and repair manual. I have searched extensively but have been unable to find any manuals other than the User, one supplied.
http://www.shouldersofshoreham.co.uk/sos_17Bamp.mvc?P=pcn-4545
Above is an exploded parts diagram, that should be of some help.
May 25, 2010 | Garden
How to change the oil pump on the chainsaw model pcn 4545
Patrick;
I could not find anything matching the number you provided. I did find an electric saw "RY43006 Chain Saw" here (follow the instructions):
Homelite/Ryobi.com (authorized parts supplier)
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
I think with the IPL as a disassembly guide replacement is pretty easy. There are a couple of hoses listed, I suspect one of them failed rather than the pump.
If this is not your saw please provide some different numbers (reply below) and I will try again. Good Luck. HTH
Lou
Feb 25, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a ryobi chain saw PCN 4545 - won't fire. Is there soemthing simple I'm not doing. Has worked efficiently for 2 years. Don't think it's flooded. Does it have a spark plug ? Would appreciate soem...
A COMMON PROBLEM FOR A CHAINSAW OVER 2 YEARS OF AGE IT IS USUALLY THAT A WIRE HAS BUSTED THAT NEEDS REPLACING CHECK FOR ASSISTANCE IN THE MANUAL IF YOU STILL HAVE IT THERE SHOULD BE AND AFTER CARE PHONE NUMBER FOR FURTHER ASSSISTANCE
Oct 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi chainsaw 4545 automatic chain lubrication not working
That number you provided does not cross to an IPL (exploded parts list) here:
Homelite/Ryobi.com
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches. It is the only illustration I've found that gives any oil line rouling detail.
Oil System Plugged.
A blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). The saw can be operated without the bar and chain to verify oiler operation. Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 27, 2009 | Ryobi Garden
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
894 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
