Question about Toshiba Satellite A15-S127 Notebook
Monitor issues!!!!! for the last 2 days my laptop's screen has been going through severely distorted stages, it'll flicker badly and have multiple horizontal lines on the screen. what can cause this to happen. its not a constant thing but it has occured quite frequently during computer usage. alan
I had this. Backlight bulb failure. Cost about 40 $ to fix yourself and 400 at shop.Not that hard,contact me for details: njyuriy@gmail.com
Posted on Aug 31, 2008
The screen on mine went dead. Then I realized that I could see the screen if I held a flashlight up to it, but just barely. Any ideas?
Posted on Aug 25, 2008
Monitor distorts colors and goes out of sync horizontally after 15 min
they dont last forever... time for replacement as most are not user-serviceable..
Mar 08, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
How do i fix a flickering screen problem of my HP Compaq 6735s laptop
The flickering could be a sign that your lcd screen is going bad and needs to be replaced. It could also be the video card inside the computer. Isolate the problem by connecting another monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without flickering, then your video card inside the computer is good, but your lcd screen is bad. If the Borrowed monitor flickers like your lcd screen did, then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Try tapping the back of the lcd screen's lid to see if the flickering stops, increases or decreases. It might be that the lcd cable located at the top on the back of the lcd screen is loose.Isolate the problem by connecting another monitor to the computer. You'll have to take the lcd apart to get to the video cable on the back of it.
May 31, 2012 | HP Compaq 6735s Notebook
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
X6000 white screen. distorted display at startup, with lines, flickering, hazy display, eventually becomes all white. Tried connecting to an external monitor, same result. Is this a video board issue? ...
1.your video card driver must have crashed try re-installing it !!
or
2.your video card must have failed !!try connecting your laptop to a CRT or LCD monitor and check it out !!! if you get the same thing in your CRT then its your video card change it if you want!!
Jun 15, 2011 | Computers & Internet
The laptop screen flickers all the time and it distorts the screen. If i plug into a desktop monitor that works fine. What is the problem? and how do i fix it?
hi chizuk, if the screen flickers all the time, pls call our support line at 1-877-4-536686. This issue needs to be addressed and it is possible for a depot repair due to screen problem.
Hope this helps...
May 08, 2010 | Lenovo IdeaPad Y510 Notebook
Flickering screen on startup
Sounds like hardware. Several possibilities come immediately to mind:
1) Backlight is going bad. (It's a fluorescent light).
2) Bad inverter
3) Loose or bad cable in laptop hinge
If the picture is OK using an external monitor, it's probably one of those three.
I've used these guys before for screen repair: Unknown document title.
http://www.notebookmechanix.com/
Feb 06, 2009 | Acer Aspire 3003LCi Notebook
Flickering screen
Yes, right click on the desktop, go to properties > settings > advanced,
Go to the monitor tab and try changing the refresh rate to something a little higher IE if it is set at 60, try 70.
Jul 18, 2008 | Philips 170P 17" LCD Monitor
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Toshiba Satellite A15-S127 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
